debug IP NAT iOS-XE
avelasquez
Hello community
    i´m trying to perform a debug ip nat command on a 4451 router  with IOS-XE 16.06.04, however this command appears not to be available anymore.
Router#debug ip nat ?
<1-99> Access list forced
WORD Access list name
ha High Availability debugging
The only options i have is to debug using thye above options but none of them show the  nat translations in real time. do you know a way to perform the debug ip nat in IOS-XE?
 Real time it seems is not available but you can use
"show ip nat translations verbose"
