default gateway question
pgrama0124
hello all,
on our network, we have two gateways to the internet, one a checkpoint firewall and the other is a cisco asa appliance. All the devices default gateway is a cisco 3500 series which handles all the routing. Basically, I want to configure some type of policy-based routing so that traffic coming from a particular IP destined to the outside would use the cisco asa appliance and the rest of the traffic default gateway would be to the checkpoint. What's the best way to do this.
paolo bevilacqua
Here is you guide:
http://cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a008081dac5.html#wp1228588
Basically, you configure ACLs that defines what goes where. An IP services image is required on the switch.
