Default Route Being Readvertised
nonamer15
I'm not sure a good title for this. I've got 2 routers directly connected to each other as below.
I've got R1 setup as a DHCP server and that's how R2 is receiving its IP information. Within that DHCP pool, I've assigned the default router as R1s ge2 IP. Afterwards, I configure RIPv2. When doing this, R2 is advertising a default route of itself to R1, which I can't figure out why it would be doing that. Below is the configuration.
R1
interface GigabitEthernet2
 ip address 10.1.1.1 255.255.255.0
ip dhcp excluded-address 10.1.1.1
ip dhcp pool 1
 network 10.1.1.0 255.255.255.0
 default-router 10.1.1.1
router rip
 version 2
 network 10.0.0.0
 no auto-summary
R2
 ip address dhcp
router rip
 version 2
 network 10.0.0.0
 no auto-summary
Below are the routing tables.
R1#
Gateway of last resort is 10.1.1.4 to network 0.0.0.0
R*    0.0.0.0/0 [120/1] via 10.1.1.4, 00:00:25, GigabitEthernet2
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.1.0/24 is directly connected, GigabitEthernet2
L        10.1.1.1/32 is directly connected, GigabitEthernet2
R2#
Gateway of last resort is 10.1.1.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 10.1.1.1
L        10.1.1.4/32 is directly connected, GigabitEthernet2
R2s routing table makes sense. I would not expect the default route on R1. I'm guessing because R2 is receiving that default route via DHCP and then advertising it via RIP, split horizon doesn't prevent that route from being advertised to R1 as it's different. Seems strange to me that R2 uses its IP within the default route, though.
I was able to prevent the above from happening with some configuration changes.
  1. Remove the 'default-router' command from the DHCP pool
  2. Add the 'default-information originate' command under the RIP configuration for R1
I'm still curious as to the behavior of R2, though. Thanks.
5 Replies 5
NetAcad506
R1
ip dhcp pool 1
router rip
 version 2
 network 10.0.0.0
 no auto-summary
R2
 ip address dhcp
router rip
 version 2
 network 10.0.0.0
 no auto-summary
R1#
R2#
Hi! I just duplicated your config, but got different results:
hostname DHCP
ip dhcp pool 1
interface FastEthernet0/1
 duplex auto
 speed auto
router rip
 version 2
 network 10.0.0.0
 no auto-summary
hostname CLIENT
 ip address dhcp
 duplex auto
 speed auto
router rip
 version 2
 network 10.0.0.0
 no auto-summary
ABOUT ROUTING TABLES:
DHCP#sho ip route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, FastEthernet0/1
DHCP#
CLIENT#sho ip route
CLIENT#
sivam siva
Level 3
Level 3
HI
Post full R2 config
nonamer15
@NetAcad506
I tried again and am still getting the same results. I'm using Cisco Modeling Labs instead of actual hardware. I wouldn't think that should matter, though.
@sivam siva
Below are the full configs for both routers.
R1
version 16.5
service timestamps debug datetime localtime
service timestamps log datetime localtime
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform console serial
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip dhcp pool 1
subscriber templating
license udi pid CSR1000V sn 9KJ5BOOKE9I
diagnostic bootup level minimal
redundancy
interface GigabitEthernet1
 no ip address
 shutdown
 negotiation auto
 no mop enabled
 no mop sysid
 negotiation auto
 no mop enabled
 no mop sysid
router rip
 version 2
 network 10.0.0.0
 no auto-summary
threat-visibility
virtual-service csr_mgmt
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R2
version 16.5
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
license udi pid CSR1000V sn 9IBB3JPLW73
redundancy
 no ip address
 shutdown
 negotiation auto
 no mop enabled
 no mop sysid
 ip address dhcp
 negotiation auto
 no mop enabled
 no mop sysid
router rip
 version 2
 network 10.0.0.0
 no auto-summary
threat-visibility
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R* indicate that default-information originate command configured under R2 RIP , but i couldn't find that in your post
Try to execute "No default-information originate" under R2 Router rip.
nonamer15
I don't have default-information originate on either on R1 or R2. I issued no default-information originate under the RIP configuration for both routers, but still no change.
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#router rip
R2(config-router)#no default-information originate
R2(config-router)#end
R2#
R1#conf t
R1(config)#router rip
R1(config-router)#no default-information originate
R1(config-router)#end
R1#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 10.1.1.2 to network 0.0.0.0
R*    0.0.0.0/0 [120/1] via 10.1.1.2, 00:00:11, GigabitEthernet2
R1#
I'm not sure why this is happening.
R2#
*Aug 26 18:23:08: RIP: sending v2 update to 224.0.0.9 via GigabitEthernet2 (10.1.1.2)
*Aug 26 18:23:08: RIP: build update entries
*Aug 26 18:23:08:       0.0.0.0/0 via 0.0.0.0, metric 1, tag 0
R2#
R1#
*Aug 26 18:23:29: RIP: sending v2 update to 224.0.0.9 via GigabitEthernet2 (10.1.1.1)
*Aug 26 18:23:29: RIP: build update entries - suppressing null update
R1#
*Aug 26 18:23:35: RIP: received v2 update from 10.1.1.2 on GigabitEthernet2
*Aug 26 18:23:35:      0.0.0.0/0 via 0.0.0.0 in 1 hops
R1#
R1#sh ip rip database
0.0.0.0/0    auto-summary
0.0.0.0/0
    [1] via 10.1.1.2, 00:00:28, GigabitEthernet2
10.0.0.0/8    auto-summary
10.1.1.0/24    directly connected, GigabitEthernet2
R1#
R2#sh ip rip database
0.0.0.0/0    redistributed
    [1] via 0.0.0.0,
R2#
