Default route propogation in BGP and VRF
awickers
I have just implemented VRF for a MPLS & Internet service on a shared 3845 platform and I have now lost my default route propagation to my remote sites.
Before implementing VRF the default route propagated fine to the remote routers and I had a route of last resort on all of them. After implementing VRF the default route was still on the 3845 but the route of last resort is no longer present on the remote routers.
It is definitely the VRF config causing the problem because as soon as I remove the vrf forwarding command from the subinterface the route of last resort appears on the remote routers, I have searched for a solution on the forum and Cisco web site without any luck. Although I think it may be something to do with routes leaking between the vrf and the global routing table.
VRF config is
ip vrf DIA
description *** DIA VRF Instance ***
rd 3549:2
route-target export 3549:2
route-target import 3549:2
interface GigabitEthernet0/1
description *** Internet Connection ***
ip vrf forwarding DIA
ip address 208.50.120.33 255.255.255.224
no keepalive
arp timeout 1500
interface Serial2/0.518 point-to-point
description ***** Internet Connection ****
bandwidth 12000
ip address 207.138.94.182 255.255.255.252
frame-relay interface-dlci 518
Static route are
0.0.0.0 0.0.0.0 10.1.3.253 (internal interface of firewall)
ip route vrf DIA 0.0.0.0 0.0.0.0 207.138.94.181
ip route vrf DIA 208.50.120.32 255.255.255.224 207.138.94.181
BGP config is
router bgp 64610
no synchronization
bgp log-neighbor-changes
network 10.z.z.z mask 255.255.240.0
redistribute static
neighbor x.x.x.x remote-as 6745
neighbor x.x.x.x ebgp-multihop 4
neighbor x.x.x.x version 4
neighbor y.y.y.y remote-as 3549
eighbor y.y.y.y local-as 64875
neighbor y.y.y.y version 4
neighbor y.y.y.y prefix-list DIA-out out
no auto-summary
address-family ipv4 vrf DIA
neighbor y.y.y.y local-as 64875
neighbor y.y.y.y activate
no synchronization
network 208.50.120.32 mask 255.255.255.224
exit-address-family
Hope someone can help.
Regards Andrew
19 Replies 19
can u submit the below please ( with VRF applied to interfaces):
1-sh ip route 10.1.3.253
2-sh ip route vrf DIA 10.1.3.253
Sam
Sam results are as follows
Without VRF enabled
router#sh ip route 10.1.3.253
Routing entry for 10.1.0.0/20
Known via "connected", distance 0, metric 0 (connected, via interface)
Advertised by bgp 64610
Routing Descriptor Blocks:
* directly connected, via GigabitEthernet0/0
Route metric is 0, traffic share count is 1
routersh ip route vrf DIA 10.1.3.253
% Network not in table
With VRF enabled
Router#sh ip route vrf DIA 10.1.3.253
Andrew
great !
you have a default route in global pointing at 10.1.3.253 which is connected to GE0/0.
under BGP (IPV4) u redistribute static to our remote sites.
Adding "default-information originate" should propagate a default route to remote sites, regardless of what happens under ur VRF config.
The VRF config as I understand is between u and remote AS for peering.
Sam
Sam
Adding the default-information originate to the BGP config worked, we now have the default route propagating out to the remote MPLS connected sites and internet access via gi0/1
Many thanks for all you help
Regards Andrew
glad to hear !
I spotted this from start, but was not too sure about ur set up and what u aimed to achieve.
Sam
