Default routing
eric.huihk
Dear all,
I have 5 routers titled router1, router2, router3, router4 , router5 connected as below:
Router1 ---------Router2 --------- Router3------------Router4--------Router5
No static route created in all routers. But just default route set on each router.
If Router1 can ping Router5 and vice versa, can i set default route on each router to the interface of both sides' router?
Any route loop if the neighboring router set default route to each other?
Many thanks
5 Replies 5
ankbhasi
Hi Eric,
It may create a routing loop in your network. Is there any specific reason you only want default route and not static routes or some basic routing protocol?
Ankur
Hi ankbhasi,
I just wonder if just using default route can ping from router1 to router5 and vice versa.
How can i set the default route? Both direction of each router need to set?
Eric,
Two default routes in the same router will not workout for you. You have to use static routes for each destination subnet you want to reach. The reason behind it is that the router will add both the default routes in its routing table and will try to load balance across these two routes. Which will result in some packets taking the one path while some of the packets taking the other path. Which means there will be a packet loop and some of the packets will never make it to the destination.
In this topology setting the default route on router R1 and R5 is OK bot if you set the default routes on the routers in the middle you will see the behaviour as mentioned above. On these routers you have to use specific static routes for every destination that you want to route.
HTH,Please rate if it does.
-amit singh
Edison Ortiz
You need to implement network routes instead of default routes. Let's say we have the following networks:
R1 <- 192.168.12.0/24 -> R2
R2 <- 192.168.23.0/24 -> R3
R3 <- 192.168.34.0/24 -> R4
R4 <- 192.168.45.0/24 -> R5
For R1 to reach 192.168.45.0/24 segment, you need the following routes:
R1:
ip route 192.168.45.0 255.255.255.0 R2
R2:
ip route 192.168.45.0 255.255.255.0 R3
R3:
ip route 192.168.45.0 255.255.255.0 R4
ip route 192.168.12.0 255.255.255.0 R2
R4:
ip route 192.168.12.0 255.255.255.0 R3
This is why dynamic routing protocol is useful. If you use RIPv2, all you need on each router:
router rip
version 2
network 192.168.x.0
no auto-summary
With EIGRP
router eigrp 1
network 192.168.0.0 255.255.0.0
no auto-summary
With OSPF
router ospf 1
network 192.168.0.0 0.0.255.255 area 0
HTH,
Hi Eric,
You can consider setup Default route in R1 pointing to R2 & default route in R5 pointing to R4. For the rest of routers, you need to use IGP route like static routes or dynamic routes for communication because each of these routers has 2 x links connnected. Please rate my post if helpful.
Leon
