delete Vlan.dat from cisco 4948 switch
itdsmartnet
hi,
when i tried to delete vlan.dat file i got the following messange.
%Error deleting cat4000_flash:cat4000_flash:vlan.dat (Permission denied)
what might be the problem.
have you tried
"erase cat4000_flash: " command as advised by the link you received from Francisco1?
BR,
Milan
8 Replies 8
i have read the above article , the problem is that when i issue the command "delete cat4000_flash:vlan.dat" it gives the following message.
%Error deleting cat4000_flash:vlan.dat (Permission denied)
please need help in deleting vlan.dat from 4948 switch.
have you tried
BR,
Milan
Thanks for your reply, it works :) ,
dont apply erase erase comand it will be a disaster. it erase ur flash file also
rfurukawasr3
Hello Everyone,
Could you help me ?? I tried the same command: "erase cat4000_flash:" after reload the switch starts on "rommon mode" ! Thanks so much !
just reboot and put the command: boot system flash bootflash:cat4500-entservicesk9-mz.150-2.SG11.bin
bootflash:cat4500-entservicesk9-mz.150-2.SG11.bin its your IOS, maybe in your sw its other
