deleted.
faizan_barmare
8 Replies 8
on the Cisco, configure the neighbor statement with:
neighbor x.x.x.x dont-capability-negotiate
where x.x.x.x is the Mikrotik neighbor...
Already tried this, But it didn,t help.
did this ever work, or is this a new install ? Did you specify a BGP router ID on both sides ?
This is new config.   Router is taking other live interface IP add as router-id.
there is other bgp session running my end router. Also There customer end router also have multiple bgp session running.
try and manually set the router ID (bgp router-id). Best to use a loopback interface for this.
Can you post the configs of both the Mikrotik and the Cisco ? Which IOS and RouterOS do the devices run, respectively ?
Can't change router-id as there are multiple bgp session with other customers, changing router-id will reset all session.
Thanks all
How did you resolve this ?
