description required of ACL
skmparvez
20 permit ip host 71.72.73.74 61.62.63.64 0.0.0.15
IP used here is just for an example. i have seen this when i put sh access-list command in a router.
can someone please describe the meaning of this line.
5 Replies 5
This ACE allows any ip traffic from the host 71.72.73.74 to the network 61.62.63.64/28, that are the adresses from 61.62.63.64-79. IOS uses wildcardmasks in ACLs, which are inverted netmasks.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
thanks a lot
I think this ACL is wrong because number 20 indicates standard access list.
Access List Type Number
Standard IP Access Lists1-99
Extended IP Access Lists100-199
We can not use destination in Standard access list.
Correct me if i am wrong ?
"20" is not the ACL-number, it's the sequence-number of the ACE in a named ACL.
