08-19-2011 01:12 AM - edited 03-04-2019 01:19 PM
To fulfill a requirement of forcing traffic to follow a different path than using the normal routing table, what other options similar to route-maps can be used.
thanks.
08-19-2011 01:31 AM
- If its Just for icmp, u can use loose or strict in extended options
For data traffic,
- If network is runing on mpls, can use mpls traffic engineering tunnels
- GRE tunnel can be routed over the new path and the destination can be pointed on to it.
Log in to Community
