09-19-2011 06:46 AM - edited 03-04-2019 01:39 PM
I have a copper over ethernet connected to an adtran 908e connected to an ASA 5505 with a port 192.168.150.254 connected to the router on the Gigabitethernet 0/0
I can ping to internal and external ip addresses but when a device is connected through the wireless signal then the device cannot ping anything;
Any thoughts what could be stopping the device from pinging any ip addresses internal and external?
I posted my current config for the router and ap:
Router:
Current configuration : 2245 bytes
! Last configuration change at 16:03:06 UTC Tue Sep 6 2011
version 15.0
hostname CivilTech
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.150.1 192.168.150.10
ip dhcp excluded-address 192.168.151.1
ip dhcp excluded-address 192.168.150.1 192.168.150.254
ip dhcp pool LAN-POOL
network 192.168.151.0 255.255.255.0
default-router 192.168.151.1
dns-server 4.2.2.2
lease 7
ip dhcp pool CivilTech
ip dhcp pool lan-pool
no ip domain lookup
license udi pid CISCO1941W-A/K9 sn FTX140580W4
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
interface GigabitEthernet0/0
ip address dhcp
ip access-group to-lan in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface wlan-ap0
description internal switch int connecting to the embedded ap
ip address 192.168.152.1 255.255.255.0
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
ip address 192.168.153.1 255.255.255.0
ip access-group from-lan in
ip nat inside
duplex auto
speed auto
interface Vlan1
ip address 192.168.151.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 192.168.150.254
ip route 192.0.0.0 255.255.255.0 192.168.150.1
ip access-list extended nat-list
permit ip 192.0.0.0 0.255.255.255 any
permit icmp 192.0.0.0 0.255.255.255 any
permit icmp any any
permit ip any any
control-plane
banner motd ^CNo Unauthorized Personel Allowed^C
line con 0
logging synchronous
line aux 0
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
logging synchronous
login
scheduler allocate 20000 1000
end
Sterling#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 192.168.150.254 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.150.254
is directly connected, GigabitEthernet0/0
S 192.0.0.0/24 [1/0] via 192.168.150.1
192.168.150.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.150.0/24 is directly connected, GigabitEthernet0/0
L 192.168.150.153/32 is directly connected, GigabitEthernet0/0
192.168.151.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.151.0/24 is directly connected, Vlan1
L 192.168.151.1/32 is directly connected, Vlan1
192.168.152.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.152.0/24 is directly connected, wlan-ap0
L 192.168.152.1/32 is directly connected, wlan-ap0
Sterling#sh ip int bri
Wlan-GigabitEthernet0/0 unassigned YES unset up up
GigabitEthernet0/0 192.168.150.153 YES DHCP up up
wlan-ap0 192.168.152.1 YES manual up up
GigabitEthernet0/1 192.168.153.1 YES manual down down
Vlan1 192.168.151.1 YES manual up up
NVI0 192.168.150.153 YES unset up up
AP:
ap>enable
Password:
ap#sh run
Building configuration...
Current configuration : 3495 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 ??????????
enable password 7 ??????????
no aaa new-model
no ip domain lookup
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.155.1 192.168.155.10
network 192.168.150.0 255.255.255.0
dns-server 4.2.2.2
lease 7
dot11 syslog
dot11 ssid CivilTechAccess
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 ??????????
username CivilTech
username ?????????? password 7 ??????????
bridge irb
interface Dot11Radio0
description 802.11bgn radio
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 1 mode ciphers tkip
broadcast-key change 3600
antenna gain 0
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
power local 14
station-role root access-point
no cdp enable
bridge-group 21
bridge-group 21 subscriber-loop-control
bridge-group 21 block-unknown-source
no bridge-group 21 source-learning
no bridge-group 21 unicast-flooding
bridge-group 21 spanning-disabled
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
mac-address 001c.58c1.c3e0
bandwidth 10000000
no ip address
no ip route-cache
shutdown
encryption mode ciphers tkip
antenna gain 0
no dfs band block
channel dfs
station-role root
payload-encapsulation dot1h
infrastructure-client
bridge-group 1
description the embedded gigabitethernet 0 is an internal int connecting ap with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.21
description 802.11bgn bridge
encapsulation dot1Q 21
no ip route-cache
bridge-group 21
interface BVI1
ip address 192.168.150.2 255.255.255.0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
permit tcp 192.168.151.0 0.0.0.255 any
permit ip 192.168.153.0 0.0.0.255 any
bridge 1 route ip
alias exec dot11radio service-module wlan-ap0 session
line con 0
line vty 0 4
login local
no exec
transport input all
end
ap#
09-24-2011 02:14 PM
Jessica,
though I have never been touching any APs, to this excerpt looks not good:
dns-server 4.2.2.2
lease 7
basically, the default-gateway is on different subnet compared to the scope being defined. I guess when you have an active device on that AP, it can't ping the AP itself?
Could you please check that?
Ivan.
