DHCP LAN customers won't connect to internet through CISCO 2620
hussainul
i'm configure cisco 2620 as a internet router. my cisco 2620 router has 5  Ethernet interface. One FE and four Ethernet interface (NM-4E). i'm configure  the FE interface as ISP internet interface. and Ethernet 1/1 as a DHCP  LAN interface. as i see my config are ok. but unable to access the  internet from LAN side. below is my config. please help me to solve  this.
Current configuration : 1498 bytes
version 12.2
service config
service timestamps debug uptime
service timestamps log uptime
hostname xxx
enable secret 5 $1$LvPI$UtOZEPSXBrf
enable password xxxxxx
ip subnet-zero
no ip routing
ip name-server 100.12.13.13
ip name-server 200.100.12.12
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp pool insideDHCP
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
dns-server 100.12.13.13 200.100.12.12
call rsvp-sync
interface FastEthernet0/0
description Broadband Internet
ip address 20.110.211.154 255.255.255.240
ip nat outside
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface Ethernet1/0
no ip address
no ip route-cache
no ip mroute-cache
half-duplex
no cdp enable
interface Ethernet1/1
description DHCP LAN
ip address 192.168.5.1 255.255.255.0
ip nat inside
no ip route-cache
no ip mroute-cache
full-duplex
no cdp enable
interface Ethernet1/2
no ip address
no ip route-cache
no ip mroute-cache
shutdown
half-duplex
no cdp enable
interface Ethernet1/3
no ip address
no ip route-cache
no ip mroute-cache
full-duplex
no cdp enable
ip nat inside source list 1 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 0.110.211.155
no ip http server
dial-peer cor custom
line con 0
exec-timeout 0 0
password xxxxxxx
login
line aux 0
line vty 0 4
password xxxxxxxx
login
end
Jon Marshall
Your NAT statement is referencing an acl that you have not defined.
I generally use an extended acl ie.
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
ip nat inside source list 101 interface fa0/0 overload
you can use a standard acl if you want but either way you need to define an acl.
Jon
this is correct please make an ACL reflecting the source list 1
"ip access-list standard 1"
"permit 192.168.5.0 0.0.0.255 any"
I offer a slightly different alternative. In my experience using extended access  lists for NAT where you are going to permit any destination can produce some complications which are avoided when you use a standard access list. So if you are going to use permit ip 192.168.5.0 0.0.0.255 any then I suggest that you make it into a standard access list and permit ip 192.168.5.0 0.0.0.255.
I also note an issue that I hope is just a typo in the default route
If this is really what is in the config then I can certainly see why nothing can access the Internet.
Rick
Rick
