DHCP on subinterface
bsudol79p
Can anyone tell me if it is possible to create 2 seperate DHCP pools on 2 subinterfaces. The reason I am asking is because I want to create a router on a stick with seperate DHCP pools. Thanks in an advance.
Jon Marshall
Bart
Yes, there is no problem with this. Either you can have separate ip helper-addresses under each subinterface or you can configure multiple DHCP pools on the router, one for each subinterface.
Jon
Jon Marshall
Bart
Jon
thanks a lot for your help. I just don't have a free router at the moment in order to test it but you got me the answers I needed. Thanks
No problem, glad to have helped.
Jon
