I have the following configuration:
interface Vlan3526
no shutdown
vrf member VRF-Red
ip address 10.111.26.1/24
ip dhcp relay address 172.25.1.77 use-vrf VRF-Blue
In my topology I have VRFs without MPLS or VPN on the following way:
VRF-Red>(use-vrf)VRF-Blue>Windows DHCP Server.
I create the configuration on a Windows 2012 Server following this instructions:
https://www.cisco.com/c/en/us/support/docs/switches/nexus-9000-series-switches/200248-Configuring-Microsoft-Windows-Server-201.html
But I dont have VPN as you can see on my config, so the dificulty is to create policys based on:
Realy Agent Information
Agent Circuit ID
Agent Remote ID
Sobscriber ID
This are the options on the W2012 R2 server.
The question is: How I can create the policy on a enviroment without VPN or MPLS, how I can calculate this information: Realy Agent Information, Agent Circuit ID, Agent Remote ID, Subscriber ID.
Thank you in advance.
