Dialer + virtual template + virtual access
rthakker
Guys I am bit confused and I want some help. I want to understand what’s difference between Dialer interface and virtual interface? In which scenario one should be using dialer interface or Virtual template? I also want to know when do u see Virtual-access interface and why?
In short I just want to understand fundamentals of all so if someone can tell me this else give me any web link where I can read else any book I can refer.
amit-singh
Level 8
Level 8
Multilink PPP uses the Virtual Access interface as a bundle interface to reassemble packets received over individual links and to fragment packets sent out over individual links.
• Dialer interfaces—Logical entities that use a per-destination dialer profile. Any number of dialer interfaces can be created in a router. All configuration settings specific to the destination go in the dialer interface configuration. Each dialer interface uses a dialer pool, which is a pool of physical interfaces (ISDN BRI and PRI, asynchronous-modem, and synchronous serial).
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_tech_note09186a0080094862.shtml#ppp
http://www.cisco.com/en/US/products/sw/iosswrel/ps1826/products_configuration_guide_chapter09186a00800d9bd5.html
http://www.cisco.com/en/US/tech/tk801/tsd_technology_support_category_home.html
HTH,
-amit singh
