Dialup Backup Problem
Phoungsakdavin
I have one router 1751 with wic-1am and 3825 with nm-8am-v2. What am doing is to configure DDR Back when my primary serial link goes down.
The router 1751 is the " Calling Router" and 3825 is the "Called Router".
The problem is when the serial interface goes down, and the backup link is then activated. As i see the debug the router 1751 is calling, but about 5 second it is disconnected. It seems the 3825 router doesn't pick up the call.
Please find the atttached file.
VIN
spremkumar
Level 9
Level 9
hi
i would suggest to use the floating static route (secondary route) pointing via the Async instead of using backup interface command.
If you shut the serial interface which has the backup interface command configured under it will inturn affect in triggering the async interface.
So i would suggest to remove the backup command and add with some admin distance.
interface Serial1
no backup delay 10 10
no backup interface Async1
no ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route 0.0.0.0 0.0.0.0 10.0.0.1 10
Also do post out your 3825 router config here..
regds
spremkumar
Level 9
Level 9
hi
interface Serial1
regds
Thank you for your reply.
I changed the routing as you above mentioned, but the problem still happen. Please see the configuration of the Router 3825 and its debug while the router 1721 is calling.
VIN
Pls change u r 3825 router config as below and check
no username xxx password xxx
