Difference between C1111-8P vs C891F-K9
JRGC
Hi guys,
I'm thinking to implement new model router for my infraestructure and I would like to kown what would be the best option.
Currently I have two MPLS provider and I will need to garatee the communication to Central Data Center. and deploy diferrent services like ( Network segmentation, Dynamic protocols, QoS, ACLs )
The main idea is that the router can receive both mpls links
Thank you for your input.
Hi Rafael,
Both models are based on Cisco IOS which comes with a wide array of networking features including and no limited to Routing Protocols (EIGRP, OSPF, BGP, etc), QoS (Low-Latency Queue, Shaping, Policing, etc), Security features (ACL, Zone-based Firewall), etc.
About the differences:
  • The C1111-8P seems to come with 2 WAN ports (1xGE & 1xGE/SFP).
  • There is an image of the rear side of the Router here.
  • The Router Data Sheet is here.
  • The platform runs Cisco IOS-XE implementation which is the de facto for newer Routers and its code is based on the Cisco IOS core.
  • Download Software site.
  • The C891F-K9 seems to come with 2 WAN ports (1xGE & 1xFE).
  • The platform runs Cisco IOS implementation which has been largely deployed in Cisco Branch Routers for years.
I hope this helps.
Regards.
Hi Rafael,
I hope this helps.
Regards.
Thanks for helping to answer this hecserra
