Difference Between L2 & L3 MPLS
gauravpundir231
Hi All,
Can guys please help me to understand the "Difference Between L2 & L3 MPLS"
Julio E. Moisa
I think it should be difference between MPLS L2 VPN and MPLS L3 VPN. Some differences are:
- On L2  the provider is not involved with the client's routing.
- MPLS L2 VPN can work like a point to point example EoMPLS also it can be more flexible using point to multipoint like VPLS and HVPLS.
- MPLS L3 VPN the provider is involved on the client routing and it use MP-BGP on each PE router in order to create a VPN, it is highly scalable and any to any connectivity, fast to implement, etc.
Here you will find a great explanation:
https://learningnetwork.cisco.com/thread/84726
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio...
Thanks for quick revert & nice document :)
You are welcome :-)
it was a pleasure my friend.
Have a great day
