Different isp, load balance without bgp
Is possible to configure wan load balance with 2 isp without bgp, with nat, using ios on 2911 cisco router? Different speeds of upload for each one..
It is possible with a static default pointing towards both of the ISPs. if you are specific towards any one of the routes then point a static route for that particular route towards both of the ISPs.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Does your feature set support PfR?  If so, it can dynamically load balance.
Julio Carvajal
Hello.
Totally Agree with Joseph that the more advanced, Scalable and dynamic way to do this will be with oer/PfR.
Now as Thanveer said you can do Equal Load Balancing via different interfaces with static routes as well.
So you have the options over the table what you will need to define are the exact requirements cause you could even use PBR to send traffic over one link depending on the source , etc (This can also be done with PfR)
It would make sense to use the link with the more available bandwith for the critical traffic and the other link for the rest of the traffic or even have the one with the highest bandwith sending all traffic and only using the secondary if the primary fails. U have many options which is good :)
Keep us Posted!
Jcarvaja
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
