Different LANs cannot connect
shawnsherwood
I am trying to connect two LANS together 172.16.2.x and 172.16.1.x. I am able to ping from ASA, but not from a workstation.
I am new to Cisco products so any help is greatly appreciated.
: Saved
ASA Version 8.2(5)
hostname sanfranciscoasa
enable password Ks2g1WIl1DTTvO3g encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 172.16.2.2 Adtran
name 172.16.1.0 Cranbury
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.16.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.172.20 255.255.255.0
ftp mode passive
clock timezone PST -8
clock summer-time PDT recurring
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 8.8.4.4
same-security-traffic permit intra-interface
access-list inside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,inside) Cranbury 172.16.2.0 netmask 255.255.255.0
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 192.168.172.1 1
route inside Cranbury 255.255.255.0 Adtran 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 172.16.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto ca trustpoint ASDM_TrustPoint0
enrollment terminal
subject-name CN=sanfranciscoasa
crl configure
crypto isakmp enable inside
crypto isakmp policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 172.16.2.0 255.255.255.255 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 172.16.2.50-172.16.2.59 inside
dhcpd dns 8.8.8.8 8.8.4.4 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username ssherwood password JkjHliTRLXMXtcz8 encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:4d6af11c0eaa87ca4977c07fc7b535a3
: end
6 Replies 6
Amit Singh
Hi Shawn,
Please could you paste the toplogy diagram? Where does 172.16.1.0 reside?
A brief topology would help.
Cheers,
-amit singh
Amit,
I don't have a diagram, but I explain the best I can,
SF 172.16.2.0
Cisco ASA 172.16.2.1
Port 0 goes to internet
Port 2 goes to Adtran T1 172.16.2.2
Cranbury 172.16.1.0
Cisco ASA 172.16.1.1
Port 2 goes to Adtran T1 172.16.1.2
So currently I can ping/trace route directly from SF ASA to Cranbury ASA, but am unable to ping via a workstation.
Hope that answers your question.
In above config both sides of the T1 need to be in the same subnet.  Yours are in two different subnets.  is this a typo?
Port 2 goes to Adtran T1 172.16.2.1/30
Port 2 goes to Adtran T1 172.16.2.2/30
AT&T had me set both of the ADtrans to match the local network at each location.
SF
Adtran ethernet side 172.16.2.2
Adtran BGP PPP side 172.16.2.0
Cranbury
Adtran ethernet side 172.16.1.2
Adtran BGP PPP side 172.16,1.0
JulietCharlie
And what about routing? Is it corectly configured?
Can you provide me output of :
sho ip route
sho ip bgp sum
if there is not 50 pages output :)).
Is it working now?
If I use the adtran as the default gateway I can ping to the other T1 and ASA. Im not at the site anymore, but when I get a chance I'll send the requested info
