Join Customer Connection to register!
373
cisc0.ameer
Beginner
DMVPN & bgp
HELLO
in DMVPN configuration (regardless of which phase)
for eBGP peering should we use from Tunnel interfaces ?
 firstly we should  established peering then  routing table(prefixes by Network command) exchanged .
because Tunnel will be created with it's own ip (first tunnel created then start to send Private prefixes such as Loopbacks)
so more logical is eBGP peering use from Tunnel interfaces which defined on Hub and spokes
1 ACCEPTED SOLUTION
Deepak Kumar
VIP Advocate
Yes, DMVPN will only work if your tunnel communication is established (HUB and Spoke) so definitely you need configure routing as BGP with tunnel interfaces.
Is BGP is underlay or overlay protocol? If you want to use an overlay then yes, you need enable BGP on tunnel protocol. If BGP is enabled as underlay protocol then you must think about another routing protocol or share your current configuration.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
3 REPLIES 3
Deepak Kumar
VIP Advocate
Deepak Kumar,
thanks for your reply
and thanks for asking extra Question for completing it
as it is a Test purpose in simulator so Hub and Spokes reach each others NBMA add directly via static routing (Underlay)
so my query was about Overlay and as you mentioned Yes it is used for Overlay
so i have to create Tunnel interface first then use its IP for eBGP peering .
balaji.bandi
VIP Expert
What is the use case here, if it is all internal and you do not have public cloud requirement, i would suggest to stick with IGP.( again based on the requirement).
BB
*** Rate All Helpful Responses ***
