dmvpn, cannot see hop override in the routing table for PHASE 3
Hi guys,
can someone please tell me what i am doing wrong here, trying to create dmvpn phase 3, spokes can trace to eachother directly. only thing is i cannot see override routes in the routing table.
Hello @ahmedsid432135621 ,
>> would you consider DMVPN is working in its current config as the spokes can communicate together?
We may consider it working but you are just testing NHRP component of the DMVPN solution.
real world DMVPN :  NHRP + appropriate IGP or BGP + IPSec tunnel profile
your lab tests only the first one.
Hope to help
Giuseppe
12 Replies 12
post the full running configs (sh run) of the hub and one of the spokes...
Giuseppe Larosa
DMVPN phase 3 is heavily based on NHRP redirect that can be performed by CEF without performance penalties.
So in DMVPN Phase 3 routing is performed with a totally different strategy then in Phase 2.
However, you should provide your configurations as already suggested to get better help
Hope to help
Giuseppe
R1#show run
Building configuration...
Current configuration : 2152 bytes
upgrade fpd auto
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
redundancy
ip tcp synwait-time 5
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel1
ip address 192.168.167.1 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp redirect
tunnel source Loopback0
tunnel mode gre multipoint
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface GigabitEthernet1/0
ip address 10.1.3.1 255.255.255.0
negotiation auto
interface GigabitEthernet4/0
ip address 10.1.2.1 255.255.255.0
negotiation auto
interface GigabitEthernet5/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet6/0
no ip address
shutdown
negotiation auto
router ospf 1
router-id 1.1.1.1
network 1.1.1.1 0.0.0.0 area 0
network 10.1.2.0 0.0.0.255 area 0
network 10.1.3.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input all
end
R6#show run
Current configuration : 2169 bytes
upgrade fpd auto
version 15.2
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 6.6.6.6 255.255.255.255
interface Tunnel1
ip address 192.168.167.6 255.255.255.0
no ip redirects
ip nhrp map 192.168.167.1 1.1.1.1
ip nhrp map multicast 1.1.1.1
ip nhrp nhs 192.168.167.1
ip nhrp shortcut
ip address 10.4.6.6 255.255.255.0
negotiation auto
router ospf 1
router-id 6.6.6.6
network 6.6.6.6 0.0.0.0 area 1
network 10.4.6.0 0.0.0.255 area 1
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input all
end
R1#show run
upgrade fpd auto
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
interface Tunnel1
no ip redirects
ip nhrp redirect
no ip address
shutdown
duplex half
negotiation auto
negotiation auto
router ospf 1
router-id 1.1.1.1
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input all
end
R6#show run
upgrade fpd auto
version 15.2
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface Loopback0
interface Tunnel1
no ip redirects
ip nhrp shortcut
no ip address
shutdown
duplex half
negotiation auto
router ospf 1
router-id 6.6.6.6
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input all
end
thanks, here is the config
you are not running any IGP over the DMVPN tunnel:
You have router ospf 1 that is executed on the underlay network
You could use EIGRP over the DMVPN bur at the moment there is no IGP over the virtual flat network built by NHRP
>> interface Tunnel1
no ip redirects
ip nhrp shortcut
router ospf 1
router-id 6.6.6.6
You can add test VLANs / subnets to be advertised using EIGRP  over the DMVPN multipoint GRE this is a safe step to avoid recursive routing error
Hope to help
Giuseppe
i never thought of that, and must have missed this implication in the books. how is it that dmvpn is functioning without the IGP?
NHRP provides the resolution protocol that solves the NBMA external address in the virtual address and that is in place.
But a useful DMVPN would need an IGP to route someting over it
Because DMVPN is a framework to build Hub and Spokes VPN Site to Site with the capabiity to setup SPoke to spoke tunnels when needed.
Interesting traffic to setup the IPSEc tunnels that is used in real world to protect the DMVPN mGRE is triggered by traffic between LAN subnets advertised over the DMVPN.
You can use an EIGRP process or a different OSPF process for the IGP over the DMVPN-
Hope to help
Giuseppe
thanks, one last question, would you consider DMVPN is working in its current config as the spokes can communicate together?
I have not followed the entire discussion, but in any case you need to announce the tunnel network in OSPF:
Hub
router ospf 1
network 192.168.167.0 0.0.0.255 area 0
Spokes
router ospf 1
network 192.168.167.0 0.0.0.255 area 1
Hello @Georg Pauwen ,
in my opinion the original poster should use a separate IGP   ( EIGRP or another OSPF process) to avoid recursive routing error.
also putting the same subnet in two different areas looks like not correct unless it is a trick
Best Regards
Giuseppe
Hope to help
Giuseppe
