571
Beginner
DMVPN Hub redundancy
I have built a two hub single spoke trial lab. the hubs are then connected to a layer 3 switch.
I have configured DMVPN without tunnel protection
My hub has a single tunnel with two nrhp entries for the two hubs
I am running OSPF for dynamic routing.
The OSPF neighbour comes up and the routing tables look good. In some cases on the L3 switch the routes see two routes to the same subnet which is perfect.
However If I shut the tunnel interface on one of my hubs. The L3 switch deletes all routes to the branch office. After some time the routes will come back in for the single hub.
I was assuming that I would get sub second failover. Or at least keep the routes that I know are still live.
Does anyone have any ideas? I'm tempted to just configure them as two separate DMVPNs.
4 REPLIES 4
VIP Advisor
Hello Can you post the config
Hello
Can you post the config for the NHS Hubs and NHC spoke please.
res
Paul
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Beginner
Hub1---------interface
Hub1
interface Tunnel61
 description DMVPN
 ip address 5.5.160.1 255.255.255.0
 no ip redirects
 ip mtu 1230
 ip nhrp authentication password
 ip nhrp map multicast dynamic
 ip nhrp map multicast 9.9.254.4
 ip nhrp map 5.5.160.2 9.9.254.4
 ip nhrp network-id 100000
 ip nhrp holdtime 120
 ip virtual-reassembly in
 ip ospf network broadcast
 tunnel source Port-channel1.160
 tunnel mode gre multipoint
 tunnel key 999
router ospf 10
 network 5.5.144.0 0.0.0.3 area 0
 network 5.5.145.0 0.0.0.3 area 0
 network 5.5.146.0 0.0.0.3 area 0
 network 5.5.147.0 0.0.0.3 area 0
 network 5.5.148.0 0.0.0.3 area 0
 network 5.5.160.0 0.0.0.255 area 0
 network 192.168.132.0 0.0.0.7 area 0
Hub2
interface Tunnel61
 description DMVPN
 ip address 5.5.160.2 255.255.255.0
 no ip redirects
 ip mtu 1230
 ip nhrp map multicast 9.9.254.3
 ip nhrp map 5.5.160.1 9.9.254.3
 tunnel key 999
router ospf 10
 network 5.5.144.4 0.0.0.3 area 0
 network 5.5.145.4 0.0.0.3 area 0
 network 5.5.146.4 0.0.0.3 area 0
 network 5.5.147.4 0.0.0.3 area 0
 network 5.5.148.4 0.0.0.3 area 0
Spoke
interface Tunnel61
 description DMVPN
 ip vrf forwarding VRF-INSIDE
 ip address 5.5.160.10 255.255.255.0
 no ip redirects
 ip mtu 1230
 ip nhrp nhs 5.5.160.1
 ip nhrp nhs 5.5.160.2
 zone-member security TUNNEL61
 ip ospf priority 0
 tunnel source FastEthernet4
 tunnel key 999
router ospf 10 vrf VRF-INSIDE
 router-id 5.5.160.10
 network 192.168.160.0 0.0.0.255 area 0
Beginner
Any Ideas?
Any Ideas?
VIP Advisor
HelloWhat  dont see is ospf
Hello
What  dont see is ospf DR/BDR defined - it looks like you have left it to negociate -
Try-
Hub1
int tun 61
bandwith 1000
ip ospf priority 3
Also can you post the following:
sh ip ospf route
sh ip ospf neighbours
sh dmvpn
sh ip nhrp
res
Paul
kind regards
Paul
Content for Community-Ad
July's Community Spotlight Awards
