DMVPN Hub to Hub
Mokhalil82
Level 4
Level 4
I have set up a DMVPN network and all then spoke to hub and spoke to spoke tunnels form as expected. I do not however get any Hub to hub tunnels.
Each of my hub routers sits in a different location with a L3 link between them. Think link is however used for other traffic aswell so I would like the hub routers to have a hub to hub tunnel.
Is this possible?
trfinkenstadt
It is possible.  Do you have the hub-to-hub tunnel configured statically in your DMVPN across the source interface for the tunnel?
I managed to configure a GRE tunnel between the two hub, so now thy can communicate over that.
