Highlighted
dmvpn + local break out to the internet
I have a dmvpn network, with multiple spokes.
One of them, needs to have a local break out to the internet.
Wasn't able to find a configuration example, so maybe if someone could show how to config it.
Basically what I need is a split tunnel configuration, to redirect the internet traffic outside of the vpn-tunnel.
here's the config of my router,
hostname testrouter
boot-start-marker
boot-end-marker
aaa new-model
aaa group server radius testradius
 server name PRO007
no ip domain lookup
ip domain name test-domain
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
track 1 list threshold percentage
 object 101
 object 102
 delay down 180 up 5
track 101 ip sla 1 reachability
track 102 ip sla 2 reachability
crypto isakmp policy 10
 encr aes 256
 group 5
crypto isakmp profile ISAKMP-DMVPN-CA
   self-identity fqdn
   ca trust-point sec-ca
   match identity host domain alert.local
   keepalive 60 retry 10
crypto ipsec transform-set ESP-AES256-SHA-TRANSP esp-aes 256 esp-sha-hmac
 mode transport
crypto ipsec profile ESP-AES256-SHA-CA
 set transform-set ESP-AES256-SHA-TRANSP
 set isakmp-profile ISAKMP-DMVPN-CA
interface Loopback0
 ip address 10.168.244.134 255.255.255.255
interface Tunnel0
 bandwidth 5000
 ip address 10.168.246.134 255.255.254.0
 no ip redirects
 no ip proxy-arp
 ip mtu 1400
 ip nhrp authentication DMVPN_05
 ip nhrp map 10.168.246.1 xxx.xxx.xxx.xxx
 ip nhrp map 10.168.246.2 xxx.xxx.xxx.xxy
 ip nhrp map multicast xxx.xxx.xxx.xxx
 ip nhrp map multicast xxx.xxx.xxx.xxy
 ip nhrp network-id 121
 ip nhrp holdtime 600
 ip nhrp nhs 10.168.246.1
 ip nhrp nhs 10.168.246.2
 ip nhrp registration no-unique
 tunnel source FastEthernet4
 tunnel mode gre multipoint
 tunnel key 121
 tunnel path-mtu-discovery
 tunnel protection ipsec profile ESP-AES256-SHA-CA shared
interface FastEthernet0
 no ip address
 spanning-tree portfast
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address dhcp client-id FastEthernet4
 ip access-group INET-INBOUND in
 no ip proxy-arp
 duplex auto
 speed auto
interface Vlan1
 ip address 10.169.6.177 255.255.255.248
 no ip proxy-arp
router eigrp 1
 distribute-list EIGRP-PERMIT-OUT out Tunnel0
 network 10.0.0.0
 passive-interface default
 no passive-interface Tunnel0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route xxx.xxx.xxx.xxy 255.255.255.255 FastEthernet4 dhcp
ip route xxx.xxx.xxx.xxx 255.255.255.255 FastEthernet4 dhcp
ip route xxx.xxx.xxx.xxw 255.255.255.255 FastEthernet4 dhcp
ip access-list standard EIGRP-PERMIT-OUT
 permit 10.169.0.0 0.0.31.255
 permit 10.168.244.0 0.0.1.255
ip access-list extended INET-INBOUND
 permit udp any any eq bootpc
 permit esp host xxx.xxx.xxx.xxy4 any
 permit gre host xxx.xxx.xxx.xxy4 any
 permit udp host xxx.xxx.xxx.xxy4 eq 2000 any
 permit udp host xxx.xxx.xxx.xxy4 any eq isakmp
 permit udp host xxx.xxx.xxx.xxy4 any eq non500-isakmp
 permit esp host xxx.xxx.xxx.xxy5 any
 permit gre host xxx.xxx.xxx.xxy5 any
 permit udp host xxx.xxx.xxx.xxy5 eq 2000 any
 permit udp host xxx.xxx.xxx.xxy5 any eq isakmp
 permit udp host xxx.xxx.xxx.xxy5 any eq non500-isakmp
 permit tcp host 193.164.88.196 eq www any
 permit udp host 193.164.88.196 eq 123 any
 permit icmp any any unreachable
 permit icmp any any echo-reply
 permit icmp any any time-exceeded
 deny   ip 10.0.0.0 0.0.0.255 any
 deny   ip 172.16.0.0 0.0.16.255 any
 deny   ip 192.168.0.0 0.0.255.255 any
 deny   ip 127.0.0.0 0.255.255.255 any
 deny   ip host 255.255.255.255 any
 deny   ip any any
ip radius source-interface Tunnel0
ip sla 1
 udp-echo 10.168.246.1 2000 control disable
 threshold 3000
 timeout 3500
 frequency 4
ip sla schedule 1 life forever start-time now
ip sla 2
 threshold 3000
 timeout 3500
 frequency 4
ip sla schedule 2 life forever start-time now
snmp-server community rvssnmp RO
snmp-server location BX
snmp-server contact Securitas RVS team
radius server SECEUAD001
 address ipv4 193.164.88.2 auth-port 1645 acct-port 1646
 key 0 V8gUp9avUruprec
line con 0
 exec-timeout 60 0
 privilege level 15
line aux 0
line vty 0 4
 exec-timeout 60 0
 transport input telnet ssh
 transport output telnet ssh
ntp server 10.168.246.1
ntp server 10.168.246.2
ntp server 193.164.88.196
ntp update-calendar
end
1 ACCEPTED SOLUTION
Highlighted
Participant
That's how it would work by default.
Only tunnel IPs and those defined by EIGRP will go through the Tunnel interface.
Please provide output of show ip route to see your gateway of last resort..
3 REPLIES 3
Highlighted
Participant
Highlighted
HI Adam,
Problem solved !
THX
Highlighted
Happy to hear it!
Content for Community-Ad
