DMVPN mGRE tunnel issue
rathinilesh
i am trying to get my hands dirty with mGRE. Please check the attached image. It a fairly basic scenario. R2 as the hub and R4 as a branch router. The eigrp neighborship between the two tunnel interfaces is not coming up. If I configure "tunnel destination 10.1.34.4" on R2 then the eigrp neighborship between the two tunnel interfaces comes up successfully. I am not sure what am I missing.
My configs are as below
R2#
crypto isakmp policy 10
encr 3des
authentication pre-share
crypto isakmp key bigsecret address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set vpn-test esp-3des esp-sha-hmac
mode transport
crypto ipsec profile VPN-DMVPN
set security-association lifetime seconds 120
set transform-set vpn-test
interface Tunnel0
bandwidth 1536
ip address 10.1.24.2 255.255.255.0
ip mtu 1300
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile VPN-DMVPN
router eigrp 24
network 10.1.12.2 0.0.0.0
network 10.1.24.2 0.0.0.0
no auto-summary
eigrp router-id 2.2.2.2
R4#
encr 3des
crypto isakmp key bigsecret address 10.1.23.2
mode transport
interface Tunnel0
bandwidth 1536
ip address 10.1.24.4 255.255.255.0
ip mtu 1300
tunnel source FastEthernet0/0
tunnel destination 10.1.23.2
tunnel key 100000
router eigrp 24
network 10.1.24.4 0.0.0.0
network 10.1.45.4 0.0.0.0
no auto-summary
eigrp router-id 4.4.4.4
answanso
Hi Nilesh,
You are missing the NHRP mappings required to make mGRE work. You will also need to disable split horizon on the hub. Try the following configuration:
R2#
interface Tunnel0
bandwidth 1536
ip mtu 1300
ip nhrp map multicast dynamic
ip nhrp network-id 100
ip hhrp holdtime 600
no ip split-horizon eigrp
tunnel key 100000
R4#
interface Tunnel0
bandwidth 1536
ip mtu 1300
ip nhrp map 10.1.24.2 fa0/1-ipaddress
ip nhrp nhs 10.1.24.2
tunnel key 100000
Here is a document that explains the configuration a little further:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_white_paper09186a008018983e.shtml
Anthony
answanso
Hi Nilesh,
R2#
interface Tunnel0
bandwidth 1536
ip mtu 1300
tunnel key 100000
R4#
interface Tunnel0
bandwidth 1536
ip mtu 1300
tunnel key 100000
Anthony
Hi Anthony,
Thank you for your reply. Your config/example worked for me. I had initially added the nhrp statements but had messed it up and couldn't bring up the tunnel. I also managed to get a Dual Hub Single DMVPN to work.
Nilesh
