02-23-2022 07:54 AM
Hi Guys
We are looking at starting a DMVPN over our MPLS network.
We have 2 main hubs.
When you create the tunnel on the spokes and you put the config in for the hubs as below
Spoke2(config-if)#ip nhrp nhs 172.16.1.1 Spoke2(config-if)#ip nhrp nhs 172.16.1.2
Does it try them in top down order of preference?
Also, what is the recommendation, should we go single, or dual cloud DMVPN?
Cheers
02-23-2022 08:17 AM
each spoke have only one Hub connect to it BUT there is DMVPN tunnel health monitor can monitor the Hub and shift to other in case of failure.
for single or dual can you confirm if the Spoke and DC have dual ISP ?
02-23-2022 09:20 AM
on the spoke you create 2 tunnels towards Hub1 and Hub 2 right ?
as per i know you can do with network id - ip nhrp network-id 1
