DMVPN Phase 1 Hub to Spoke connection
Sunny Banks
Hi all,
Hopefully you can help me out. I'm trying to configure a DMVPN phase 1 Hub to Spoke connection (only mGRE and NHRP). On the hub my tunnel 0 interface is up/down and i'm unsure why. I've triple checked the tunnel config. (NBMA and tunnel IP's etc.) and it all looks good. I'm using a default route on the hub and spokes and have full connectivity site to site using the underlay network. I've added the relevant config. below :-
HUB
interface Tunnel0
ip address 10.1.1.1 255.255.255.0
no ip redirects
ip nhrp network-id 10
tunnel source 15.0.0.1
tunnel mode gre multipoint
interface Serial0/0
ip address 15.0.0.1 255.255.255.0
clock rate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
SPOKE
interface Tunnel0
ip address 10.1.1.2 255.255.255.0
ip nhrp map 10.1.1.1 15.0.0.1
ip nhrp nhs 10.1.1.1
tunnel source 25.0.0.2
tunnel destination 15.0.0.1
interface Serial0/1
ip address 25.0.0.2 255.255.255.0
clock rate 2000000
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1
I'm not using any routing protocols, only default routes on the hub and spokes but (as mentioned above) have full connectivity yet still can't get the hub tunnel 0 to move from up/down. The spoke is looking good in terms of the tunnel 0 being up/up and output from sh ip nhrp.
Any help is much appreciated,
Sunny
24 Replies 24
balaji.bandi
Had quick look on te Hub side,  hub is missing the nhs server command.
Hub :
inteface tunnelX
  ip nhrp nhs x.x.x.x
Also tweak the hold timer.
BB
in additio to the other post, I think you also need to map the multicast:
interface Tunnel0
ip nhrp map multicast 15.0.0.1
Gents,
I applied the suggested config :-
HUB
interface Tunnel0
no ip redirects
ip nhrp holdtime 1
SPOKE
interface Tunnel0
ip nhrp holdtime 1
Unfortunately issue still persists. Tunnel 0 on the HUB is still up/down :-
R1#sh ip int t 0
Tunnel0 is up, line protocol is down
Internet address is 10.1.1.1/24
Broadcast address is 255.255.255.255
R1#sh ip nhrp
<no output>
Any further suggestions?
Your help is greatly appreciated,
Sunny
Ok going back to basic question, do you have undelay reachability between Hub and Spoke ?
can you post full configuraiton of the bothe device and post any topology to understand.
show us the reachability with ping each other side.
BB
Full configs (with suggested config changes) attached.
Full configs with suggested config changes attached.
Topology
Assuming that you have reachability on the physical interfaces, on both Hub and Spoke could you change the tunnel source to the physical interface.
If the tunnel comes up, you would also need to add ip nhrp map multicast dynamic under the Hub tunnel interface.
Applied but issue still persists.
from spoke
ping 15.0.0.1 source 25.0.0.2
Gents,
I have applied the latest suggestions to no avail. Issue still persists. As requested full configs :-
HUB
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip icmp rate-limit unreachable
ip cef
ip tcp synwait-time 5
ip audit po max-events 100
no ip domain lookup
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Tunnel0
no ip redirects
tunnel source Serial0/0
interface FastEthernet0/0
duplex auto
speed auto
interface Serial0/0
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface FastEthernet3/0
no ip address
shutdown
interface FastEthernet3/1
no ip address
shutdown
interface FastEthernet3/2
no ip address
shutdown
interface FastEthernet3/3
no ip address
shutdown
interface FastEthernet3/4
no ip address
shutdown
interface FastEthernet3/5
no ip address
shutdown
interface FastEthernet3/6
no ip address
shutdown
interface FastEthernet3/7
no ip address
shutdown
interface FastEthernet3/8
no ip address
shutdown
interface FastEthernet3/9
no ip address
shutdown
interface FastEthernet3/10
no ip address
shutdown
interface FastEthernet3/11
no ip address
shutdown
interface FastEthernet3/12
no ip address
shutdown
interface FastEthernet3/13
no ip address
shutdown
interface FastEthernet3/14
no ip address
shutdown
interface FastEthernet3/15
no ip address
shutdown
interface FastEthernet4/0
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
no ip http server
no ip http secure-server
no cdp log mismatch duplex
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
SPOKE
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Tunnel0
tunnel source Serial0/1
interface Tunnel1
no ip address
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
interface Serial0/3
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
no ip http server
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2#ping 15.0.0.1 source serial 0/1
Sending 5, 100-byte ICMP Echos to 15.0.0.1, timeout is 2 seconds:
Packet sent with a source address of 25.0.0.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/24/28 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/24/24 ms
R1#ping 25.0.0.2 source serial 0/0
Sending 5, 100-byte ICMP Echos to 25.0.0.2, timeout is 2 seconds:
Packet sent with a source address of 15.0.0.1
