DMVPN problem with NAT
prafuljaded
Level 3
Level 3
Hi All,
Does anyone know why we have so many NAT entries as below ?
We are running DMVPN EIGRP topology in our network. The DMVPN hub aggregates all the spoke router networks via the tunnel. ALso the Spoke routers allow internet traffic by using NAT and only private traffic flows through the DMVPN tunnel. The IPSec is up and running fine and EIGRP works good. Serial int overload for NAT is configured.
Brief configs on Hub and Spoke are as below:
Spoke router:
interface Tunnel0
description VPN tunnel
bandwidth 400
ip address 172.28.1.159 255.255.252.0
ip nhrp authentication xxx
ip nhrp map 172.28.1.1 6x.xx.x.x
ip nhrp network-id 100000
ip nhrp holdtime 360
ip nhrp nhs 172.28.1.1
ip summary-address eigrp 100 10.159.0.0 255.255.0.0 5
delay 40000
qos pre-classify
tunnel source Serial0/0/1:0
tunnel destination 6x.xx.x.x
tunnel key xxxx
tunnel protection ipsec profile pppp
Hub Router:
interface Tunnel0
bandwidth 100000
ip address 172.28.1.1 255.255.252.0
no ip redirects
ip nhrp map multicast dynamic
ip nhrp network-id 100002
no ip split-horizon eigrp 100
load-interval 30
delay 40000
qos pre-classify
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key xxxx
Rt#sh ip nat trans | i :500
udp 20x.y.y.y:500 10.159.99.251:500 6.x.x.x:500 6.x.x.x:500
The problem is when I get this entry in the NAT table of Spoke router, Crypto breaks and EIGRP goes down on the spoke router and DMVPN tunnel is completely down.
10.159.99.251 is gig0/0.99 private ip of the spoke router. I am not sure why we have some many entries for this UDP 500 ISAKMP connection instead of just one.
This happens even if any PC behind the Spoke router tries to establish IPSec connection with the hub router( which is not at all necessary)
Praful
b.speltz
Level 4
Level 4
I think the tunnel get shuts down becoz the time and date when the tunnel registration expires and the DMVPN tunnel will be shut down.
