02-01-2019 05:27 AM - edited 02-01-2019 08:19 AM
I'm in the process of designing a spoke to spoke DMVPN solution with iBGP routing.
The spoke to hub communication works fine (PC1 & PC2 can successfully ping 10.10.1.1) but not the spoke to spoke's (PC1 & PC2 can't ping each other).
Any idea why?
Hardware:
Spokes: Cellular routers connecting through SIMs.
Hub: Cisco 2900 Series connecting through ADSL.
Diagram:
GRE addressing:
Hub: 192.168.1.1
Spoke1: 192.168.1.2
Spoke2: 192.168.1.3
Hub's running conf:
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
lifetime 3600
crypto isakmp key xxxx address 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set DMVPN esp-3des esp-md5-hmac
mode transport
crypto ipsec profile DMVPN
set security-association lifetime seconds 86400
set transform-set DMVPN
interface Loopback0
ip address 10.10.1.1 255.255.255.0
interface Tunnel0
no ip redirects
ip nhrp authentication xxxx
ip nhrp map multicast dynamic
ip nhrp network-id 1
no ip nhrp record
no ip nhrp cache non-authoritative
keepalive 20 3
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile DMVPN
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 86.x.x.x 255.255.255.240
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router bgp 65500
bgp router-id 192.168.1.1
bgp log-neighbor-changes
bgp listen range 192.168.1.0/24 peer-group DMVPN
bgp listen limit 500
neighbor DMVPN peer-group
neighbor DMVPN remote-as 65500
neighbor DMVPN timers 30 180
address-family ipv4
network 10.10.1.0 mask 255.255.255.0
network 192.168.1.0
neighbor DMVPN activate
neighbor DMVPN next-hop-self
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 86.x.x.x
Hub's routing table:
Gateway of last resort is 86.x.x.x to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 86.x.x.x
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.1.0/24 is directly connected, Loopback0
L 10.10.1.1/32 is directly connected, Loopback0
86.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 86.x.x.x/28 is directly connected, GigabitEthernet0/0
L 86.x.x.x/32 is directly connected, GigabitEthernet0/0
B 192.168.0.0/24 [200/0] via 192.168.1.2, 01:51:54
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Tunnel0
L 192.168.1.1/32 is directly connected, Tunnel0
B 192.168.2.0/24 [200/0] via 192.168.1.3, 00:00:43
I thought it could be because the spokes don't know where to send the traffic toward one another so I added the following IP range to the Hub’s iBGP routing address-family so it advertises it to the spokes:
Network 192.168.0.0 mask 255.255.0.0
But it didn’t work… The spokes won't take it for some reasons.
Whereas they do take:
Network 10.10.1.0 mask 255.255.255.0
Which is also advertised by the Hub…
KR
Mike
02-01-2019 08:56 AM
Hello Mike,
Since I don't have a view of your Spoke configuration, there a few lines I suggest you add to the Hub and Spoke.
1. Add ip nhrp redirect on the Hub tunnel interface
2. Add neighbor peer-group route-reflector-client on the Hub BGP
3. On the Spokes add ip nhrp redirect.
Cheers
02-01-2019 08:58 AM
Thanks!
I'll try this and come back to you.
02-01-2019 09:21 AM
Mike,
Another thing to note is that 192.168.0.0 and 192.168.2.0 are known networks by the Spokes and not the Hub, so those networks should be advertised from the Spokes and not the Hub.
02-04-2019 01:53 AM
They are.
02-01-2019 08:59 AM
02-04-2019 02:51 AM
Makes sense, thanks for the explanation.
I was asked to use BGP, it was part of the project specifications.
I wish I could.
Unfortunately the spokes (cellular routers) won't let me add a static route with the GRE as interface, it's not even in the dropbox...
I've informed our supplier about this.
I've added "ip nhrp redirect" on both the hub and spokes and "ip nhrp shortcut" on the spokes but no joy :/
Same with the route-reflection-client setting.
I thought it could simply be my PCs (behind the spoke routers) firewalls blocking the traffic but they are disabled...
Thanks all for your help so far.
02-04-2019 03:16 AM - edited 02-04-2019 04:01 AM
Question:
Is it normal that I can't ping the GRE client IPs from a spoke to another?
Yet the spokes do have a route for 192.168.1.0/24 through 192.168.1.1 (hub's GRE IP)
192.168.0.100 (behind spoke 1 - GRE IP is 192.168.1.2) can't ping spoke 2's GRE IP (192.168.1.3) for example.
02-04-2019 06:30 AM
I think it's best you post the complete configs for Hub and Spokes, and not just the Hub, so that we can have a better insight.
Secondly, whatever routing device you ping from must have the destination network in it's routing table or learn a default through a dynamic protocol or statically configured route.
02-04-2019 07:38 AM
You're right.
Re-posting hub's as it changed slightly.
Hub's conf (current):
encr 3des
hash md5
group 2
lifetime 3600
mode transport
interface Loopback0
interface Tunnel0
no ip redirects
ip nhrp redirect
keepalive 20 3
tunnel key 0
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
router bgp 65500
address-family ipv4
network 192.168.1.0
neighbor DMVPN route-reflector-client
exit-address-family
no ip http server
Spokes' conf (its the same for both, excepted, obviously, the GRE IPs and the LANs) :
As a reminder:
GRE addressing:
Spoke1: 192.168.1.2
Spoke2: 192.168.1.3
Spokes' LANs:
Spoke1: 192.168.0.0/24
Spoke2: 192.168.2.0/24
Spokes routing table:
This is Spoke1's.
Spoke2's is the same apart from the br0 interface which is 192.168.2.0/24.
Some possibly helpful info from the hub:
02-04-2019 07:46 AM - edited 02-04-2019 08:08 AM
"Secondly, whatever routing device you ping from must have the destination network in it's routing table or learn a default through a dynamic protocol or statically configured route."
I agree completely.
How come I can't ping Spoke2's GRE IP from Spoke1 though?
Yet, both spokes have got a route to 192.168.1.0/24 and the hub's got routes to both spokes...
And it can't be down to ICMP being disabled at any end as Spoke2's GRE IP is pingable from the hub and the hub's GRE IP is pingable from both spokes...
I thought it could be caused by the "no ip redirects" setting on the GRE tunnel interface (Tunnel0) so I removed it but it didn't help unfortunately :(
