Highlighted
Beginner
Re: DMVPN - spoke to spoke comm not working
I've managed to add static routes to the spokes towards one another but they still can't ping each other.
Spoke1:
192.168.2.0/24 through 192.168.1.1
Spoke2:
192.168.0.0/24 through 192.168.1.1
Highlighted
Enthusiast
Adding static routes to each spoke would do nothing.
You haven't confirmed if your cellular routers are Cisco or a different vendor.
Does your traffic have to traverse a firewall? If so, have you checked to see if their are any hits on the Firewall?
Could you do the following:
1. Remove crypto profile on the tunnel interfaces for both Hub and Spokes and test
2. Replace DMVPN config on Cisco Hub router with GRE only to each spoke with no crypto. If it works, then that confirms that your cellular routers have an issue integrating DMVPN with Cisco.
