DMVPN Tunnel Interface having Total output drops
sudhir.rai
I have created tunnel interface 3101 with source interface as Dialer 1 , now the tun 3101 is showing output drops while the dialer is clean.
I have tried to clear counters on tun 3101 but no use....can you please suggest what could be the reason for this and how can i solve this.
PLease note there is no impact as such as i am able to reach the detsination, but because of this our monitoring tool gives an alert which needs to be resolved ...
attaching you the sh run in tun 3101 , sh int tun 3101 and sh int dia 1 output
interface Tunnel3101
description XXXXXX
bandwidth 2048
ip address x.x.x.x 255.255.255.0
no ip redirects
ip mtu 1400
ip bandwidth-percent eigrp 251 75
ip hello-interval eigrp 251 15
ip hold-time eigrp 251 45
ip flow ingress
ip nhrp authentication XXXX
ip nhrp map multicast  x.x.x.x
ip nhrp map  x.x.x.x  x.x.x.x
ip nhrp network-id 3101
ip nhrp holdtime 300
ip nhrp nhs  x.x.x.x
ip nhrp nhs  x.x.x.x
delay 10001049
tunnel source Dialer1
tunnel mode gre multipoint
tunnel key 3101
tunnel protection ipsec profile CCCCC shared
hold-queue 4096 in
hold-queue 4096 out
end
POWveSJPyokoh01#sh int tun 3101
Tunnel3101 is up, line protocol is up
  Hardware is Tunnel
  Description: ** xxxxxxxxxxxxx**
  Internet address is 3.185.204.59/24
  MTU 17850 bytes, BW 2048 Kbit/sec, DLY 100010490 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source x.x.x.x (Dialer1)
   Tunnel Subblocks:
      src-track:
         Tunnel3101 source tracking subblock associated with Dialer1
          Set of tunnels with source Dialer1, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport multi-GRE/IP
    Key 0xC1D, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1410 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "xxx_DMVPN")
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 01:46:10
  Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 462
  Queueing strategy: fifo
  Output queue: 0/4096 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
     5652 packets input, 518255 bytes, 0 no buffer
     Received 0 broadcasts (974 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1555 packets output, 148188 bytes, 0 underruns
     0 unknown protocol drops
POWveSJPyokoh01#sh int dial 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: *** XXXXXXXXXXXXXXXXXX***
  Internet address is x.x.x.x/32
  MTU 1500 bytes, BW 2048 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2d23h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1536 kilobits/sec
     282541 packets input, 54877999 bytes
     96891 packets output, 11502662 bytes
Bound to:
Virtual-Access2 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoE vaccess, cloned from Dialer1
  Vaccess status 0x44, loopback not set
  Interface is bound to Di1 (Encapsulation PPP)
  Last clearing of "show interface" counters 1w2d
  Output queue: 0/40 (size/max)
     814920 packets input, 139563240 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     307082 packets output, 36208384 bytes, 0 underruns
     0 carrier transitions
paolo bevilacqua
That is normal, likely you have ADSL with low uplink bandwidth, from that the drops. You can try to streamline and simplify configuration  to get better performances, eg. MTU values are wrong, etc.
