DNS issue
wasahongNYC
hello everyone,
I'd like to ask some question about DNS issue.
Please help me when you get a chance.
Thanks in advance.
For easy to understand, I just simplified the diagram.
now, the connectivity is
from router and switch, I can ping 4.2.2.2,
it works very well.
also,
when I ping www.google.com by Gi0/0 interface of router,
it works very well.
but,
when I tried to ping www.google.com by Gi0/1 interface of router,
it does NOT work.
the same issue with the switch as well.
that's it.
I appreciate your help since I stuck at this issue for almost 1 week.
router configuration
upgrade fpd auto
version 12.4
service password-encryption
hostname on-router-1
boot-start-marker
boot-end-marker
logging buffered emergencies
enable password 7 055B0F04715F1F5B4A44
no aaa new-model
ip cef
ip domain round-robin
ip domain name xxxxxx
ip name-server 4.2.2.2
archive
log config
hidekeys
interface Loopback100
description mgmt interface
ip address 10.0.100.13 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0
description ISP A circuit order XXXXXXXXXX
ip address *.*.*.* 255.255.255.248
ip accounting output-packets
ip nat outside
ip nat enable
no ip virtual-reassembly
duplex full
speed 1000
media-type sfp
no negotiation auto
interface GigabitEthernet0/1
description uplink to on-main-1 interface g 1/0/12
ip address 192.168.2.253 255.255.255.0
ip nat inside
ip nat enable
duplex full
speed 1000
media-type sfp
no negotiation auto
standby 2 ip 192.168.2.254
standby 2 priority 110
standby 2 preempt
interface GigabitEthernet0/2
ip address 192.168.3.253 255.255.255.0
no ip redirects
duplex full
speed 1000
negotiation auto
standby 3 ip 192.168.3.254
standby 3 priority 110
standby 3 preempt
interface GigabitEthernet0/3
no ip address
duplex full
speed 1000
no negotiation auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 *.*.*.*
ip route 10.1.0.0 255.255.0.0 192.168.2.1
ip route 10.1.20.0 255.255.255.0 192.168.2.13
no ip http server
ip dns server view-group XXXXX
ip dns server
ip nat pool inside 192.168.0.0 192.168.0.253 netmask 255.255.255.0
ip nat source list 100 interface GigabitEthernet0/0 overload
logging alarm informational
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
access-list 100 permit ip any any
access-list 100 permit udp any any
control-plane
gatekeeper
shutdown
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 5
password 7 045802150C2E
login
end
switch configuration
version 12.2
no service pad
hostname on-main-1
boot-start-marker
boot-end-marker
enable secret 5 $1$zuuI$IrnVd/YzecdoMi/oEnyoI1
enable password 7 1511021F0725
no aaa new-model
switch 1 provision ws-c3750x-12s
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
ip address 10.0.100.15 255.255.255.255
no ip address
shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
switchport access vlan 2
switchport mode access
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
description uplink to asa12 port 0/0
interface GigabitEthernet1/0/6
description uplink to router02 port g 0/1
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
description uplink to asa11 port 0/0
interface GigabitEthernet1/0/12
description uplink to router01 port g 0/1
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 192.168.2.4 255.255.255.0
ip default-gateway 192.168.2.254
ip http server
ip http secure-server
logging esm config
line con 0
line vty 0 4
password 7 02050D480809
login
line vty 5
login
line vty 6 15
login
monitor session 1 source interface Gi1/0/12
monitor session 1 destination interface Gi1/0/2
end
jawad-mukhtar
Level 4
Level 4
ip nat  source list 100 interface GigabitEthernet0/0 overload - See more at:  https://supportforums.cisco.com/message/3869592#3869592
no ip nat source list 100 interface GigabitEthernet0/0 overload
ip nat inside source list 100 interface Gigabitethernt 0/0 overload
*** Do Rate Helpfu Posts***
Jawad
14 Replies 14
jawad-mukhtar
Level 4
Level 4
Jawad
hi Jawad,
it can work, thanks,
but ...
they are NAT messages showing up.
There is still something wrong with NAT.
may you help me check it when you are free ?
I am going to search it on Google as well.
Thank you very much,
*Feb 28 12:56:23.544: NAT*: Can't create new inside entry - forced_punt_flags: 0
*Feb 28 12:56:23.544: mapping pointer available mapping:0
*Feb 28 12:56:23.544: NAT: [0] Allocated Port for 192.168.2.4 -> *.*.*.*: wanted 64542 got 64542
*Feb 28 12:56:23.544: NAT: i: udp (192.168.2.4, 64542) -> (4.2.2.2, 53) [0]
*Feb 28 12:56:23.544: NAT (UDP-DNS): Before Translation
*Feb 28 12:56:23.544: NAT: Translation of UDP DNS src 192.168.2.4, dst 4.2.2.2
*Feb 28 12:56:23.544: NAT: Dns type of Query
*Feb 28 12:56:23.544:   : dns len=20, id=38, aa=0, tc=0, rd=1, ra=0
*Feb 28 12:56:23.544:   : opcode=0, rcode=0, qdcount=1
*Feb 28 12:56:23.544:   : ancount=0, nscount=0, arcount=0
*Feb 28 12:56:23.544: NAT (UDP-DNS): After Translation
*Feb 28 12:56:23.544: NAT: s=192.168.2.4->*.*.*.*, d=4.2.2.2 [0]
*Feb 28 12:56:23.556: NAT: o: udp (4.2.2.2, 53) -> (*.*.*.*, 64542) [1435]
*Feb 28 12:56:23.556: NAT (UDP-DNS): Before Translation
*Feb 28 12:56:23.556: NAT: Translation of UDP DNS src 4.2.2.2, dst *.*.*.*
*Feb 28 12:56:23.556: NAT: Dns type of Response
*Feb 28 12:56:23.556:   : dns len=116, id=38, aa=0, tc=0, rd=1, ra=1
*Feb 28 12:56:23.556:   : opcode=0, rcode=0, qdcount=1
*Feb 28 12:56:23.556:  : ancount=6, nscount=0, arcount=0
*Feb 28 12:56:23.556:     query name is www.google.com, qtype=1,
*Feb 28 12:56:23.556: Answer section:
*Feb 28 12:56:23.556:   Name='www.google.com'
*Feb 28 12:56:23.556:   RR type=1,, ttl=230, data length=4
*Feb 28 12:56:23.556:     IP=74.125.26.99
*Feb 28 12:56:23.556:     IP=74.125.26.106
*Feb 28 12:56:23.556:     IP=74.125.26.103
*Feb 28 12:56:23.556:     IP=74.125.26.147
*Feb 28 12:56:23.556:     IP=74.125.26.105
*Feb 28 12:56:23.556:     IP=74.125.26.104
*Feb 28 12:56:23.556: Authority section:
*Feb 28 12:56:23.556: Additional record section:
*Feb 28 12:56:23.556: NAT (UDP-DNS): After Translation
arvind_data
use this configuration , it will work
R1#sh run
Building configuration...
Current configuration : 814 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R1
ip name-server 4.2.2.10
ip address 1.1.1.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 100 interface FastEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 1.1.1.1
line con 0
line vty 0 4
login
end
R1#
R1# ping
Protocol [ip]:
Target IP address: 4.2.2.10
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.2.253
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 4.2.2.10, timeout is 2 seconds:
Packet sent with a source address of 192.168.2.253
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/9/14 ms
R1#
I can ping IP but I am not able to ping domain.
Your Access-list Wild Card Bit is wrong
no access-list 100 permit ip 192.168.0.0 0.0.255.255 any
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
Jawad
Check Default Router Next Hope is Valid Hope
ip route 0.0.0.0 0.0.0.0 interface gigabit 0/0
*** Do Rate Helpful Posts***
Jawad
my router is 7201 series.
when I configure ip route 0.0.0.0 0.0.0.0 interface gigabit 0/0
I was not able to type the word "interface",
only ip route 0.0.0.0 0.0.0.0 gigabit 0/0
after this,
it was getting worse,
pinging IP(4.2.2.2) was not working.
the point is that I need both 192.168.2.0 / 24 and 192.168.3.0 / 24 for failover.
for simplicity, I didn't post the full diagram.
Looks like you have enabled 2 kinds of nat- So the natting order is different depending on which one you are using.
Never used both at the same time so I cannot comment on the effects, I would suggest to use one or the other but not both.
Your nat pool is specifying non routable ip address, the pool should be public ip addressing  so nat can translate into from  your lan subnet specified by your acl , in any case you haven't specified the pool in the final nat translation command.
Also your acl  has contradicting ace statements.
Try this:
int gig0/
ip nat outside
no ip nat enable
int gig0/1
ip nat intside
no ip nat enable
no access-list 100
access-list 1 permit ip 192.168.0.0 0.0.255.255
ip nat inside source list 1 interface gig0/0 overload
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
thanks,
but it is not working either.
how are you ping dns from your Gig 0/1.  Other thing this is not at client side mean to say Inside LAN users.
Jawad
Post your recent config
Jawad
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip nat pool mypool X.X.X.X X.X.X.X netmask 255.255.255.252
ip nat inside source list 1 pool mypool overload
access-list 1 permit 192.168.2.0 0.0.0.255
It is working now.
Thank you so much for the help
It can work even I did NOT configure this,
int gig0/
ip nat outside
no ip nat enable
int gig0/1
ip nat intside
no ip nat enable
thank you anyway,
