DNS not Working on Cisco 877
jaidan2003
Hi Guys,
I have a Cisco Route 877 to connect to the internet but it would not resolved any DNS. We do not have a DNS server and I am trying to use the 877 to resolve DNS. Am I missing something?
Below is my Config file for Cisco 877. Need your help.
Building configuration...
Current configuration : 5002 bytes
version 12.4
no service pad
hostname XXXXX
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
enable secret 5 XXXXXXXXXXXX
no aaa new-model
clock timezone PCTime 10
clock summer-time PCTime date Mar 30 2003 3:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-1189342284
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1189342284
revocation-check none
rsakeypair TP-self-signed-1189342284
crypto pki certificate chain TP-self-signed-1189342284
certificate self-signed 01
  30820250 308201B9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31313839 33343232 3834301E 170D3032 30333031 30313436
  30345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31383933
  34323238 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D825 AAE8EEAB 6F4D889E A14B96E3 EBB300B8 27ECF863 D66E316D
6C05DC4D
  ECF43846 7B51BE28 B2C1E8AF F1A08551 B24644A3 F2758E1E 15833A09 B1CB6D9F
  0B57D90D 0F82E8A7 DED2304D 775C28D0 1A2F3969 7B0604FF DE3A2406 5E11FF98
  B37DAE01 367D21D8 908799BE E87AD49C DEDFE06B 81360309 9A9D6F86 092F9221
  6A750203 010001A3 78307630 0F060355 1D130101 FF040530 030101FF 30230603
  551D1104 1C301A82 18466F6F 74736372 61792E79 6F757264 6F6D6169 6E2E636F
  6D301F06 03551D23 04183016 8014B7AE FEDE3F79 53DCC836 6B95B999 DA66803C
  7CC8301D 0603551D 0E041604 14B7AEFE DE3F7953 DCC8366B 95B999DA 66803C7C
  C8300D06 092A8648 86F70D01 01040500 03818100 71614F06 EA905A73 A41907DF
  D1D8C89A 4BE1E2C2 4B69D14D 02AABA12 89045005 B9D6E3D8 833628DA
CC4257AA
  4F213F9A 39A17E4B BB1BB316 38B0204F 711769E9 F972A368 60C5507E 85535559
  B18FBFDF 7D2D3904 40FA1FFC B6D042A8 777757F5 2D8747D4 90807B47 C2E3A59F
  6FF7000F A0EAC67B 04E2B625 D34518BE B79BC2E3
        quit
dot11 syslog
no ip source-route
ip dhcp excluded-address 10.3.3.254
ip dhcp pool ccp-pool1
   network 10.3.3.0 255.255.255.0
   default-router 10.3.3.254
ip cef
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
username admin privilege 15 secret 5 $1xxxxxxxxxxxxxx
archive
log config
  hidekeys
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.3.3.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname company@isp.com.au
ppp chap password 0 abcde
ppp pap sent-username company02@isp.com.au password 0 abcde
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.3.3.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Thank you and regards
Michael
As Richard pointed out, you are missing two things here.
You need to make IOS router as dns forwarder.
You can do that by "ip name-server x.x.x.x" (x.x.x.x can be your ISP DNS server or public DNS server like 4.2.2.2)
Then, you need to configure DNS server in DHCP pool, so PC will get DNS server information when they get IP address from DHCP server.
So, do below.
Conf t
ip name-server y.y.y.y --> usually, ISP give you primary and secondary DNS server IP addresses.
ip dhcp pool xxx
dns-server x.x.x.x y.y.y.y
KK
jaidan2003
Sorry Typo error on:
ppp pap sent-username company02@pig.tpg.com.au password 0 abcde
But still cannot reolsve DNS
Michael
Richard Burts
Michael
The first issue is that I do not see anything in this router config that tell the router where any DNS server is that it could use to resolve names. In the information that the service provider gave you with the Internet connection was there any information about DNS servers that you should use? (and there are a number of DNS servers available in the Internet that you can use in addition to whatever your provider may have). Getting this configured is the first major step in resolving issues with how get name resolution.
Rick
Rick
So, do below.
Conf t
ip dhcp pool xxx
KK
