- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-04-2023
08:15 AM
- last edited on
02-09-2023
09:31 PM
by
Translator
I have a 1921 router, which are being used as DNS server.
Over time the DNS cache reaches typically around 4-5000 entries, and the process begins to use cpu heavily around 95 %.
As an intermediate solution I have made a EEM script which monitors SYS-3-CPUHOG in the log, and do a
clear host *.
But why is this happen suddenly - the router have been run ning for several years without problems.
Thanks for your time.
Solved! Go to Solution.
- Labels:
Other Routers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 01:45 PM
why you not use external Server ??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 01:48 PM
To be honest Cisco router not a full level of DNS Server (and that too lower end model)
You have 2 Options
1. If you do not need DNS Server (not sure what is the need here) use google DNS
2. you already have the option of EEM Script clear host * ( you can lower the time of EEM Script watchdog timers )
if this impacting performance - the suggest to use Public DNS.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 11:03 AM
how old is the router, and what IOS version are you running ? Since the router is end of life/end of sale as of 2018, it is probably quite old, and running (I am guesing) a 15.x IOS. The problem could be caused by memory leaking. Instead of clearing the host table, I would suggest to occasionally reboot the device, and check if that makes a difference.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 11:55 AM
Yoy’re right, its suite Old - I dont know the exact age. Its running 15.0.
I have been collecting some statistics every 5 min, and can observe that in the time up to cpu hog the DNS cache entries increases with around 100 per minute.
DNS attach?
This also happens at times where no users are at work.
And can happen more than one time during a day.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023
12:16 PM
- last edited on
02-09-2023
09:28 PM
by
Translator
show hosts
<<- can I see this ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023
12:17 PM
- last edited on
02-09-2023
09:28 PM
by
Translator
Make sure you have IP CEF enabled.
Also, can you post a sample output of
show the process CPU sorted and show process CPU | ex 0.00
if possible post-DNS configuration. if this acts as a DNS Server limit with ACL only Local IP use as DNS Queries and allows from router to go out to root DNS, check if that may be helpful.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 01:21 PM
IP chef is enabled.
Attached are output of desired commands.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 01:45 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023
02:31 PM
- last edited on
02-09-2023
09:36 PM
by
Translator
Most of my devices gets ip through DHCP.
Should I just change the DHCP pool - dns-server 8.8.8.8 8.8.4.4 (or any other external):
p dhcp pool Pool1
import all
network 192.168.1.0 255.255.255.0
dns-server 192.168.1.1 8.8.8.8
default-router 192.168.1.1
and disable dns server:
no ip dns server
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023
02:34 PM
- last edited on
02-09-2023
09:37 PM
by
Translator
dns-server 8.8.8.8 192.168.1.1 <<- try this and not disable ip dns server,
this I think make Client use 8.8.8.8 then if failed it will used your router (GW).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 01:48 PM
You have 2 Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 03:37 PM
I have a similar problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-04-2023 04:59 PM
follow same suggestion. or uplift the model to latest or offload DNS to Rasberry Pi (pi-hole)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2023 09:48 AM
"But why is this happen suddenly - the router have been run ning for several years without problems."
Yea, no doubt that's true, but it could be something as simple as your users are more active, and/or some new application, creating even more DNS requests than years past. Possibly the proverbial straw that breaks the camel's back.
I was just examining 15.x M&T DNS documentation. Didn't find any commands to control DNS cache.
Depending what specific 15.x version you're on, moving to the latest (or final) release in your train, or moving to a later 15.x version, might deal with this issue better (if you can still obtain either). However, like many of the other posters, using your 1921 for a somewhat busy (?) DNS server, is probably not an ideal situation. I.e. move the DNS function off it.
Since you've found using an EEM script, clearing the DNS cache works well, rather than waiting just on a CPU hog message, you might also have an EEM script clear your DNS cache, once daily, ideally when router least used. (I.e. the purpose of clearing cache daily, is to avoid the router getting to a CPU hog point.)
If you wanted to try to further identify why cache is filling up, showing the contents of the DNS cache (show hosts), might help with such analysis.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2023
09:51 AM
- last edited on
02-09-2023
09:38 PM
by
Translator
@Joseph W. Doherty one of the post-op have provided the full output of
show host
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-05-2023
03:24 PM
- last edited on
02-09-2023
09:39 PM
by
Translator
show host
Thanks @balaji.bandi , I missed seeing that.
Looking at that hosts listing, though, I wonder about some of the IPs (e.g.: 104.40.191.174, 51.104.28.80, 165.160.13.20, 165.160.15.20, etc.) that list so many DNS names and/or the group of DNS names using a local loopback IP (127.0.0.1).
