DNS Servers
Network_kenn
I recently setup 2 new servers at my organization. Each server is at a separate site on 2 different subnets. At each site there is a Domain controller/DNS. I've pointed each domain controller to its self as the primary DNS address and the secondary DNS would be the next site. I have also sent both addresses to the network administrator to place them in the DHCP scope of the cisco router. Both addresses show up when I run a IP Config. When I turn off the primary domain controller the secondary domain controller does not communicate with the clients.but if the primary domain controller is online and I statically assign the secondary address to a clien it resolves to the domain name. What could possibly be the issue why the secondary domain controller does not take over the domain
Sounds like your DC's are not in sync, I would say check AD replication between them  first then also see if the dns servers are actually authorised in AD, however this is a question for a windows forum not cisco
Kind Regards
Paul
are these Windows clients ?
Yes windows
Actually I meant the clients, I assume the clients are Windows clients as well ?
So the domain controllers are the DNS servers ? And the clients have both DNS servers (ipconfig /all) ?
What if you issue the 'ipconfig /flushdns' on one of the clients after the primary domain controller goes down ?
Kind Regards
Paul
