shelley_wang
Beginner
Does Catalyst 4900m support IP-SLA?
Catalyst 4900m does not support command "ip sla <entry-number>" like Catalyst 6500. If 4900 does support SLA, how to configure it then?
Switch(config)#ip sla ?
  key-chain  Use MD5 authentication for IP SLAs control message
  responder  Enable IP SLAs Responder
Switch#sh ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(53)SG2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 16-Mar-10 02:39 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1240D93C
ROM: 12.2(44r)SG5
Darkside Revision 0, Jawa Revision 11, Tatooine Revision 140, Forerunner Revision 1.78
Switch uptime is 2 weeks, 4 days, 6 hours, 31 minutes
System image file is "bootflash:cat4500e-ipbase-mz.122-53.SG2.bin"
cisco WS-C4900M (MPC8548) processor (revision 2) with 524288K bytes of memory.
Processor board ID JAE150800ZJ
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from PowerUp
1 Virtual Ethernet interface
40 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
thx,
Shelley
1 ACCEPTED SOLUTION
Sorry - my bad. Try now:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/swipsla.html
If this was helpful you can rate for other to use it in future.
Nik
HTH,
Niko
4 REPLIES 4
nkarpysh
IP SLA is supported in 12.2(53)SG - the release you use but not in ipbase image. Ipbase supports only responder functions as you saw.
Here is the relase:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst4500/12.2/53SG/configuration/swipsla.html
Note Switches running the IP base image support only IP SLAs responder functionality and must be configured with another device that supports full IP SLAs functionality, for example, a switch.
Enterprise image should definitely support it but you can check further in Cisco feature navigator to see all the other features you need:
http://tools.cisco.com/Support/Fusion/sfselectmdf.do?mySession=422560&myStep=7
Hope this helps,
Nik
HTH,
Niko
Hi Nik,
You are right. By the way, I cannot access the configuration link for Cat 4500.
thx,
Shelley
Nik
HTH,
Niko
Hi Nikolay,
Thanks for all your help!
shelley
