Does Cisco831 support frame-relay encapsulation?
esande
Hi, I intend to order cisco831 for my frame-relay link. Does this model support frame-relay?
thnks
ch
ankurbhasin
Level 9
Level 9
Hi Ch,
I do not think frame relay is supported on 831 router as it is not mentioned in feature navigator and data sheet.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Search by platform
Also data sheet does not specify this
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a008010e5c5.html
But I will recommend you to consult your cisco system engineer for the same.
Ankur
