Routing
Labels
I'm trying to configure a HWIC-16A as a terminal server without success. I can get a telnet session to connect, but I simply get a blank screen, no data appears to be sent or received over the serial line.The only similar post I could find was https:...
Hello all,  On Border Edges(DC01-BE001-6/7) am trying to advertise default route from GRT to MPBGP-EVPN but not able to do it properly with the following configruration. Thanks in advance for tips and correction **************************************...
uni1389 by Level 1
  • 438 Views
  • 11 replies
Hello, everyone. I understand that OSPFv3 separates links from prefixes and purposely moves the prefix information from T1/T2 LSAs into T8/T9. The RFC states the following: o The Hello packet now contains no address information at all. Rather,...
Mitrixsen by Level 1
  • 243 Views
  • 5 replies
Hello, everyone. Why are link-local addresses that are used for next hops advertised in type 8 LSAs? Doesn't the router already know them considering that they are used to form the OSPFv3 adjacency? Thank youDavid
  • 272 Views
  • 2 replies
Anyone is preparing ccie service provider lab. I am looking for group where we can collaborate our study discussion so we can exchange our concepts and it helps definitely to boost preparation.Keep learning...
amjsajid by Level 1
  • 190 Views
  • 1 replies
Dear All , After having the old faithful 5515 on guard I am trying to migrate to a vFMC with a NGFW. Many issues arise with S2S and bugs in the GUI , BUT I am experiencing an other issue with a simple port forwarding. I have the same ACL - source out...
I learned that MED is applied to outbound updates , dictating the best inbound traffic into the AS, but I saw the vice-versa is also true like you can apply med for indbound updates also and it works the same right??
Hi , am trying to advertise default Mgmt-Vrf route to GRT so that other devices reachable to default route . thanks for tips and tricks . Configuration is mentioned below .  DC01-leaf03-55#show run int giga0/0interface GigabitEthernet0/0vrf forwardin...
uni1389 by Level 1
  • 576 Views
  • 5 replies
Unanswered Topics
