10-26-2011 12:06 PM - edited 03-04-2019 02:03 PM
I need to setup a vlan between 3 devices that will tolk over the WAN.
Device 1
6509 with CatOS / IOS
ON MSFC:
Interface Vlan 200
ip address 10.10.10.1 255.255.255.248
On switch:
set vtp domain mccmh
set vlan 200 7/37
set port speed 7/37 100
clear trunk 7/37 1-199,201-699,701-1005,1025-4094
set trunk 7/37 on dot1q 200,700,1006-1024
et spantree portfast 7/37 enable trunk
Device 2:
On 2600 Router:
interface FastEthernet0/0
description OPTEMAN ERS Interface
no ip address
speed 100
half-duplex
interface FastEthernet0/0.100
bandwidth 10000
encapsulation dot1Q 200
ip address 10.10.10.2 255.255.255.248
On the 6509 here are the sh logs:
show port capabilities 7/37
Model WS-X6148-GE-TX
Port 7/37
Type 10/100/1000
Speed auto,10,100,1000,auto-10-100
Duplex half,full
Trunk encap type 802.1Q
Trunk mode on,off,desirable,auto,nonegotiate
Channel yes
Broadcast suppression no
Flow control receive-(off,on,desired),send-(off,on,desired)
Security yes
Dot1x yes
Membership static,dynamic
Fast start yes
QOS scheduling rx-(1q2t),tx-(1p2q2t)
CoS rewrite yes
ToS rewrite DSCP
UDLD yes
Inline power no
AuxiliaryVlan 1..1000,1025..4094,untagged,dot1p,none
SPAN source,destination
COPS port group 7/25-48
Link debounce timer yes
Dot1q-all-tagged yes
Auto MDIX yes
Jumbo frames no
sh port 7/37
* = Configured MAC Address
# = 802.1X Authenticated Port Name.
Port Name Status Vlan Duplex Speed Type
7/37 connected trunk half 100 10/100/1000
sh trunk
* - indicates vtp domain mismatch
# - indicates dot1q-all-tagged enabled on the port
$ - indicates non-default dot1q-ethertype value
Port Mode Encapsulation Status Native vlan
7/37 on dot1q trunking 200
15/1 nonegotiate isl trunking 1
16/1 nonegotiate isl trunking 1
Port Vlans allowed on trunk
7/37 200,700,1006-1024
15/1 1-4094
16/1 1-4094
Port Vlans allowed and active in management domain
7/37 200
15/1 10,20,30,100-101,200
16/1
Port Vlans in spanning tree forwarding state and not pruned
7/37 200
16/1
-----------and on the 2600 ------------------------
CCESSRTR1#sh int fa0/0.100
FastEthernet0/0.100 is up, line protocol is up
Hardware is AmdFE, address is 0007.851b.d540 (bia 0007.851b.d540)
Internet address is 10.10.10.2/29
MTU 1500 bytes, BW 10000 Kbit, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 200.
THe lines how connect and sh cdp nei shows the other side.
I cannot ping in either direction to a ip in the vlan 200 (10.10.10.1-3)
What am I missing?
10-26-2011 02:49 PM
Duplicate post.
