double nesting policy
Mohit Chauhan
Hi friends
I am very new to QoS side of things.
And basically I have a setup where I need to build up the network with standard QoS used by the company.
Now here the challenge is that I need to use that standard but need to tweak a bit to cater for the exclusive requirement at this Branch office site.
The client normally uses shaping on the wan interface with a nested service policy inside say policy A.
This service policy calls out for different class maps and follow from there.
I wanted to introduce a new service policy say B which would match based on ACL and then do bandwidth percent to one traffic and apply service policy A. On the other hand, I would match the other traffic and do bandwidth remaining and use the same service policy A again.
My Q was could we do it this way or there was a better way of doing it??
My two ACLs are used identify local traffic from the remote traffic which is coming off another remote site piggyback this site to go back to the head office. I want to prioritize the local traffic over the remote.
Thanks in advance.
Mohit
Hello
Can you post your exiting QOS policies?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Hi Paul
The config is below. policy-map "PM-WAN" is the standard policy which I was thinking to move under a new policy "PM-SPLIT" so I can priortize the traffic for Local traffic and then apply the same standard again:
class-map match-any CM-BULK-DATA
match ip dscp af11  af12
class-map match-any CM-CRITICAL-DATA
match ip dscp af21  af22
match ip dscp af31
class-map match-any CM-INTERACTIVE-VIDEO
match ip dscp af41  af42
class-map match-any CM-NETWORK-CONTROL
match ip dscp cs2  cs6
class-map match-any CM-CALL-SIGNALLING
match ip dscp cs3
class-map match-any CM-VOICE
match ip dscp ef
class-map match-any CM-SCAVENGER
match ip dscp cs1
policy-map PM-WAN
class CM-VOICE
  priority percent 18
class CM-INTERACTIVE-VIDEO
  bandwidth percent 15
class CM-CALL-SIGNALLING
  bandwidth percent 5
  random-detect dscp-based
class CM-NETWORK-CONTROL
  bandwidth percent 5
class CM-CRITICAL-DATA
  bandwidth percent 27
class CM-BULK-DATA
  bandwidth percent 4
class CM-SCAVENGER
  bandwidth percent 1
class class-default
  fair-queue
class-map match-all LOCAL-TRAFFIC
match access-group name GSF-Traffic
class-map match-all REMOTE-TRAFFIC
match access-group name MUN-Traffic
policy-map PM-SPLIT
class LOCAL-TRAFFIC
  bandwidth percent 60
  service-policy PM-WAN
class REMOTE-TRAFFIC
  bandwidth percent 40
policy-map SHAPE
class class-default
  shape average 1900000
  service-policy PM-SPLIT
int g0/0
ip address x.x.x.x y.y.y.y
service-policy output SHAPE
I did some testing in the GNS using 7200 routers and with the following version
Cisco IOS Software, 7200 Software (C7200-ADVSECURITYK9-M), Version 12.4(24)T7, RELEASE SOFTWARE (fc2)
and it worked fine. The device did not throw any error or warning. and i could see policy being used.
Now the thing is that in production environment, the device is 3900 routers with the following IOS:
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
What is the best way to check if this IOS/device can support the three level hieraricalMQC.
somewhere i was reading that the three level was only applicable for policing.....not sure then how this 7200 did not throw any error.
Also when I tried on the GNS using 3600 router, it actually threw me an error which when i googled seemed to be for the same policing thing....
the error msg was "CBWFQ : Hierarchy supported only if shaping is configured in this class"
Any feedback will be appreciated friends!
Cheers,
Mohit
