Doubt about VSS
c-velazquez
Hello team i have a doubt about the configuration of VSS.
Let me explain, i have 4  6500 on VSS then i have 2  domain ID, but for a mistake  i configured both with the domain ID 100, then both have the same virtual MAC ID,  i going to change the  domain with the  following procedure.
switch virtual domain 10
switch convert mode virtual
After that reset the VSS.
The doubt that i have is, if when i do this change  the domain VSS will be destroy and i will need to recreate again or if it is transparent.
Regards and im sorry but  i dont speak  english
Furose M
Level 3
Level 3
its transparent. your steps are accurate. you can go ahead and proceed in the same way. it will fix the issue.
After that save config and restart the VSS.
Furose M
Level 3
Level 3
