Doubt between BGP/OSPF
Mani kandan
What is the major difference between OSPF and BGP ? Why cant v use the OSPF as EGP to ISP ( Global Internet routing ) ?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Perhaps the major difference between OSPF and BGP, if we're dealing with Internet size route tables, is BGP's capacity to handle a large number of routes (like the 400,000 or so in the Internet).
You could use OSPF between yourself and your ISP (assuming the ISP was willing), but such might only be used for passing your routes to the Internet and receiving just a default.
Thanks  a lot Mr.joseph ,
So only because of routing table size we can't use the OSPF on internet ? else anyother difference based on the operation.?
Imagine If internet table size small in that scenarion can we use the OSPF top route traffic between autonomus systems..
Disclaimer
Posting
As also noted by Mahmoodmkl, Internet also uses BGP for its routing policy management features.
BTW, within an AS, an ISP is probably using an IGP like IS-IS (or OSFP or EIGRP).
mahmoodmkl
Level 7
Level 7
In addition BGP gives more attributes for route manipulation n its its best for controlling route selection etc
