doubt in value the speed backplane router 2600
r-barbosa
hi all
I am researching as against which the value of the backplane of a router, is there any command that I check that or a datasheet on the cisco site. The backplane of any router. I ask because I'm doing a report for acquisition of new equipment and want to justify buying this showing values ​​and showing how the company's equipment are outdated. Anyone have this information?
paolo bevilacqua
Router performances information have been discussed and posted many, many times. Use search function.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I've seldom, if ever, seen documentation on most routers' backplane performance.  Generally, especially on small routers, the typical bottleneck is CPU performance.  I.e. you'll run out of forwarding performance before you would run out of backplane capacity.  The second bottle neck I've noticed is bandwidth of most small router's module slots, especially the WIC size/type modules.  This is occasionally noted on Q&A datasheets, and generally only becomes important when working with Ethernet interfaces.  Again, though, you'll likely to run out of CPU performance before module slot bandwidth capacity becomes an issue especially if you're also using built-in Ethernet interfaces.
If I were to guess, I would suspect most small Cisco routers use some variant of a PCI bus for their backplane.  (I believe recall some of the 7200s actually mention using PCI buses.)
