DPD, Dead Peer Detection
Matt Addy
Hi All,
I'm facing an issue with two DMVPN spoke sites that have a regular bad Internet connection. When the spokes go down and I get an alert from NOC the outside Internet connection is still up. I have to SSH across the Internet and do a int tu0 shut no shut to get the tunnel working again. I have DPD set but it seems to not make a difference. Tu0 always shows as up/up and I notice packet loss on outside int, this is not something the ISP is willing to look at. At first I thought about writing an EEM script using an ip sla to ping the hub and bounce the tunnel if the track goes down. But there must be an easier way..
Thanks in advance.
paolo bevilacqua
Update IOS and check again. You can also remove encryption to make things simpler, faster and more stable.
