DR Site Connectivty
syedraheel
Hello!
A company has a central site at location A with DR site connected to it via fiber link. It has brance offices at locations B, C and D. Now I want a solution where If Site A fails the traffic seamlessly routes to the DR site. What could be the best design for this scenario how should the brance offices be connected to Central site and the DR site. My manager said that it can't be a point 2 point links, what other options do we have to provide connectivity.
ktwaddell
What about putting all 5 sites on to MPLS? that way all sites can connect to each other, then you can configure your DC as a backup.
Kev
Mohamed Sobair
Level 7
Level 7
The only option I can think of to replace the dedicated point to point links is to have (MPLS).
with MPLS , you emulate those point to point links over a shared infrastructure and reduce costs.
The best design is to have two (Centeral Services) MPLS VPN services, between all branches to the DR and between all branches to the Central site.
Mohamed
Thanks a lot guys
Cheers
if you're replys were useful, please rate the posts
thanks
kev
