DSL maxed out? Or config issue?
coleman.noc
Good day,  we are getting delay when trying to access web,  at least 5 second delay when going to websites.  speedtest varies from 1.6 to 5.7mB.  Oracle Database long transactions are dropping and needing to be restarted.
Should  be a 7MB DSL.
Are the  BW 5000 Kbit/sec, RxBW 7000 Kbit/sec, DLY 20000 usec, correct?  I read these are only QOS related, but no QOS on device.
i#sh int dialer 1
Dialer1 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: *** DSL Line; Telco: Xplorrnet; 7MB ADSL;
  Internet address is 206.x.x.x/32
  MTU 1500 bytes, BW 5000 Kbit/sec, RxBW 7000 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 20/255, rxload 18/255
  Encapsulation PPP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi1
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 02:25:34
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 3750 kilobits/sec
  5 minute input rate 515000 bits/sec, 116 packets/sec
  5 minute output rate 402000 bits/sec, 105 packets/sec
     1150130 packets input, 661961995 bytes
     1111863 packets output, 371688884 bytes
Bound to:
Virtual-Access1 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 5000 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 22/255, rxload 27/255
  Encapsulation PPP, LCP Open
  Open: IPCP
  PPPoE vaccess, cloned from Dialer1
  Vaccess status 0x44, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di1 (Encapsulation PPP)
  Last input 00:00:03, output never, output hang never
  Last clearing of "show interface" counters 02:24:55
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 540000 bits/sec, 133 packets/sec
  5 minute output rate 436000 bits/sec, 125 packets/sec
     1150184 packets input, 661977650 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1112236 packets output, 371818783 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
i#sh int atm 0
ATM0 is up, line protocol is up
  Hardware is MPC ATMSAR (with Alcatel ADSL Module)
  MTU 4470 bytes, sub MTU 4470, BW 576 Kbit/sec, DLY 720 usec,
     reliability 255/255, txload 194/255, rxload 244/255
  Encapsulation ATM, loopback not set
  Encapsulation(s): AAL5  AAL2, PVC mode
  23 maximum active VCs, 1024 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 02:25:49, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6316
  Queueing strategy: Per VC Queueing
  5 minute input rate 552000 bits/sec, 131 packets/sec
  5 minute output rate 440000 bits/sec, 125 packets/sec
     1157819 packets input, 704180229 bytes, 0 no buffer
     1113233 packets output, 405401791 bytes, 0 underruns
i#sh atm interface atm 0
Interface ATM0:
AAL enabled:  AAL5   AAL2, Maximum VCs: 23, Current VCCs: 1
VCIs per VPI: 1024,
Max. Datagram Size: 4528
PLIM Type: ADSL - 512Kbps Upstream, DMT, TX clocking: LINE
1850 input, 2 output, 1293339 IN fast, 1094027 OUT fast
Avail bw = 512
Config. is ACTIVE
i#sh ip int brief | i up
FastEthernet0              unassigned      YES NVRAM  up                    up
FastEthernet0.1            172.x.x.x    YES NVRAM  up                    up
FastEthernet0.2            10.x.x.x      YES NVRAM  up                    up
FastEthernet2              unassigned      YES unset  up                    up
ATM0                       unassigned      YES NVRAM  up                    up
ATM0.1                     unassigned      YES unset  up                    up
Vlan1                      172.27.x.x  YES NVRAM  up                    up
Loopback129                172.27.x.x  YES NVRAM  up                    up
Tunnel129                  172.27.x.x  YES NVRAM  up                    up
NVI0                       172.27.x.x    YES unset  up                    up
Dialer1                    206.x.x.x  YES IPCP   up                    up
Virtual-Access1            unassigned      YES unset  up                    up
interface Dialer1
description *** DSL Line; Telco: Xplorrnet; 7MB ADSL; ACCT#119970; Support#8668416001
bandwidth 5000
bandwidth receive 7000
ip address negotiated
ip nat outside
ip nat enable
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxxxxxx@xxxxx.net password 7 3429387409213
crypto map SWM_CMAP_1
end
swmwinrtrpri#sh run int atm 0
Building configuration...
Current configuration : 209 bytes
interface ATM0
bandwidth 576
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
end
swmwinrtrpri#sh ver
Cisco IOS Software, C180X Software (C180X-ADVIPSERVICESK9-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 10:45 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH8, RELEASE SOFTWARE (fc2)
swmwinrtrpri uptime is 2 hours, 50 minutes
System restarted at 12:05:28 CST Tue Jan 14 2014
System image file is "flash:c180x-advipservicesk9-mz.124-15.T9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1801 (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FHK103819P4, with hardware revision 0000
9 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
31360K bytes of ATA CompactFlash (Read/Write)
10 Replies 10
Leo Laohoo
What is the model of your router?
Looks like your DSL link of 7 Mbps is not enough.
I see that too,  is the ATM0 interface related to the dialer interface?   I see bandwidth on Dialer 1 as 5000kbits,  why does the ATM interface have low BW?  From my undestanding the dialer interface is virtual to get PPPoE going. And the ATM0 is the physical interface? Thanks for the feedback.
i#sh int dialer 1
  Hardware is Unknown
ATM0 has high tx and rx,
     reliability 255/255, txload 175/255, rxload 220/255
  Last input 1d23h, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 53158
  5 minute input rate 498000 bits/sec, 138 packets/sec
  5 minute output rate 397000 bits/sec, 141 packets/sec
     22570119 packets input, 634384451 bytes, 0 no buffer
     22057060 packets output, 3522141260 bytes, 0 underruns
  Hardware is Unknown
  Internet address is X.X.X.X
     reliability 255/255, txload 15/255, rxload 15/255
  Last clearing of "show interface" counters 1d22h
  5 minute input rate 434000 bits/sec, 112 packets/sec
  5 minute output rate 301000 bits/sec, 114 packets/sec
     22476151 packets input, 4121222661 bytes
     22015302 packets output, 2802519072 bytes
What model is your router?
You may need to configure traffic shapping.  Notice on the ATM interface you have output drops.  This means that the remote end device of the ATM interface is dropping packets.
Ashish Arora
Coleman,
I cheked the configuration and it seems like your active bandwidth is somewhere close to 512kbps.
VCIs per VPI: 1024,
Avail bw = 512
Config. is ACTIVE
On the dialer interface:-
On virtual access interface:-
THese 3 results evidently showed that your net bandwidth asllowed acording to the Telco and according to the line rate is not more than .5 megs.
We can enable ATM layer traffic shapping or can enable policing under the dialer interface to privent this.
Please try the following command:-
Policy-map TEST
class class-default
police rate percent 99
Please make sure you change the bandwidth statement under the dialer as 512kbps , else calculation will be done according to the current bandwidth command which is manually 5000 kbps.
interface dialer 1
bandwidth 512000
Apply policy to the dialer:-
interface dialer 1
service-policy out TEST
Once this policy will be configured please take the output of :-
show policy-map interface dialer 1
It will show you the offered rate and drop rate , drop rate will be observed once policer will start polcing above 512.
NEXT ACTION:-
1. Please provide the above outputs (show policy-map int dia 1)
2. show interface dia1
3. Change th hold-queue valus under the dialer to 100 (hold-queue 100 out)
4. Confirm with the telco about the line rate and allowed bandwidth.
_THnak you
Ashish
Here are the results, I dont see any current drops,  may have to check it later.  Why would the DSL interace ever be at 512k?  Is one interface for upstream vs downstream..?   I know I have heard of 512 k upstream and 5MB download for DSL. Please clarify for understanding.  thanks.
swm#show policy-map interface dialer 1
Dialer1
  Service-policy output: TEST
    Class-map: class-default (match-any)
      54714 packets, 8975000 bytes
      5 minute offered rate 213000 bps, drop rate 0 bps
      Match: any
      police:
          rate 99 %
          rate 506500 bps, burst 15828 bytes
        conformed 54714 packets, 9560818 bytes; actions:
          transmit
        exceeded 0 packets, 0 bytes; actions:
          drop
        conformed 394000 bps, exceed 0 bps
swmwinrtrpri#sh int dia 1
  Hardware is Unknown
  Internet address is 206.XX.XXX.XXX/32
  MTU 1500 bytes, BW 512 Kbit/sec, RxBW 7000 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 183/255, rxload 155/255
  Last clearing of "show interface" counters 5d23h
  Output queue: 0/100/64/0 (size/max total/threshold/drops)
     Available Bandwidth 384 kilobits/sec
  5 minute input rate 4261000 bits/sec, 407 packets/sec
  5 minute output rate 368000 bits/sec, 255 packets/sec
     66292230 packets input, 4121136452 bytes
     65724589 packets output, 3828847484 bytes
Bound to:
     reliability 255/255, txload 19/255, rxload 213/255
  Open: IPCP
  5 minute input rate 4190000 bits/sec, 430 packets/sec
  5 minute output rate 378000 bits/sec, 277 packets/sec
     66292456 packets input, 4121247276 bytes, 0 no buffer
     65724843 packets output, 3828932426 bytes, 0 underruns
You could run a " show dsl int atm 0" to see your upstream / downstream more then likely these are not the same.
swm#show dsl interface atm 0
ATM0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:     0x03                            0x2
Vendor ID:       'STMI'                          'BDCM'
Vendor Specific: 0x0000                          0xA196
Vendor Country:  0x0F                            0xB5
Chip ID:         C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   55%                             49%
Noise Margin:    22.0 dB                         23.0 dB
Output Power:    19.0 dBm                        12.0 dBm
Attenuation:     29.0 dB                         18.0 dB
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0xDF
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      8258 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-3.0.014_no_bist.bin
Operation FW:    AMR-3.0.014.bin
FW Source:       embedded
FW Version:      3.0.14
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          5760                0           512                 0
Cells:            898508338                0     627339511                 0
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             1                 0
Header Errors:            0                0             0                 0
Total BER:                0E-0           0E-0
Leakage Average BER:      0E-0           0E-0
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 0 3 4 6 6 6 6 7 7
010: 7 7 8 8 8 8 7 7 7 7 6 6 6 5 5 5
020: 0 6 7 8 8 8 8 8 9 9 9 9 9 9 9 9
030: 9 9 9 9 8 8 8 8 8 8 8 8 8 8 9 9
040: 0 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
050: 2 9 9 9 9 9 9 8 9 8 9 8 8 9 8 9
060: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
070: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
080: 8 8 8 8 7 8 7 7 7 7 7 7 7 7 7 7
090: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 6 7
0A0: 7 7 7 7 7 7 7 7 7 6 7 7 7 7 7 7
0B0: 7 6 6 7 6 7 7 7 6 6 6 6 6 6 6 6
0C0: 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6
0D0: 6 6 6 6 6 5 6 6 5 6 6 5 4 5 5 5
0E0: 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
0F0: 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 4
DSL: Training log buffer capability is not enabled
This would be your downstream speed  5760 and your upstream is 512k.
You could check with your telco if they have a dsl profile with better upstream.
Talk to your ISP and get them to sort this problem out.  You've got a bad line.  Attenuation should be 20 dB and BELOW.
