07-24-2012 11:07 AM - edited 03-04-2019 05:03 PM
Attached is a picture of my network.
RedHat Linux Host 1 has a Eth0 with 172.21.0.17/19. Eth1 has 172.21.32.17/19.
Since Linux (and all operating systems) can have only a single default gateway, we need to figure out how to have some routes for the Eth1 interface.
My local switches are in Layer 2 and in VLAN1. They are connected up to a router with an inside interface on the same subnet with Eth0 (gateway) and Eth1.
Because I have a default gateway on Eth0, I have no problem pinging the 10.0.3.1 NTP server that you see beyond my router. When I unplug the cable on Eth0 I lose my ability to ping the NTP server since there is no route via Eth1.
So, I know this is a more of a Linux question but I thought maybe someone here has come across this before.
Thanks in advance for any help you can provide. My fingers are practically bloody from all the Googling I have been doing on this topic.
Oh, and the first suggestion I usually get is to just bond the NICs...unfortunately, our application does not support the bonding.
07-24-2012 11:51 AM
what do you want exactly ? fallover on eth1 for this 10 network ? then why not just put 2 routes to this network, one with a longest match through eth0 and the other with a shorter match through eth 1 ? the default will then be used for other remote subnets other than the 10 network.
Regards.
Alain
07-24-2012 11:55 AM
What I need to do is, when my Eth0 switch goes down (and my NIC with it), I need my host to send packetsto the 10.0.3.1 via 172.21.32.3 router since my default gateway router is unreachable.
James
07-24-2012 12:33 PM
Wouldn't it be what you are searching for ?
http://kindlund.wordpress.com/2007/11/19/configuring-multiple-default-routes-in-linux/
Regards.
Alain
07-25-2012 05:56 AM
Unfortunately, that is not it.
The issue here is with the Linux kernel in that it doesn't appear to remove the default route out Eth0 when a cable is unplugged or the switch goes down.
The ping packets to the 10.x.x.x network still try to go out Eth0. When I run an ifdown eth0 then the packets will see the route on Eth1 since the default route finally gets taken away.
But that is a manual intervention I cannot implement.
07-25-2012 06:20 AM
maybe you could do a script which flushes the primary default route when a ping to next-hop is failing( a little bit like implementing static routing with EOT on Cisco devices)
Regards.
Alain.
