dual homed ASA is using both NAT/PAT addresses
Wan_Whisperer
Beginner
Beginner
So I have an ASA Dual homed using IP SLA with tracking for my routes to set outside1 as the primary link:
nat (any,outside1) after-auto source dynamic Internal interface
nat (any,outside2) after-auto source dynamic Internal interface
route outside1 0.0.0.0 0.0.0.0 XXX.XXX.54.XXX 1 track 1
route outside2 0.0.0.0 0.0.0.0 XXX.XXX.108.XXX 254
The issue is that somehow a few devices are getting NATted to XXX.XXX.108.XXX (outside2)
How can I prevent devices from NATting to outside2 unless outside1 is down?
Thanks for your help!
balaji.bandi
VIP Community Legend VIP Community Legend
i beiieve you should use below syntax for the backup route
route backup 0.0.0.0 0.0.0.0  XXX.XXX.108.XXX 254
refer below guide :
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118962-configure-asa-00.html
BB
Cristian Matei
Collaborator
Collaborator
   Maybe at some point the SLA went down and thus routing/NAT changed? For those IP's which get NAT'ed by the second NAT statement, run a "packet-tracer" and see which route/NAT entry does it match.
Cristian Matei.
Recognize Your Peers
