Dual HUB multiple spokes DMVPN IPSEC
bymc
The test setup is two hub routers (Cisco 2921) and three spoke routers (Cisco 2901).
Testing the dual hub and three spoke without IPSEC I can remove one hub from the network and traffic continues to flow. I was able to take one hub off line as long as I left at least one hub online did not matter which hub.
Testing the dual hub and three spoke with IPSEC running I can remove one hub from the network and traffic will continue as long as the hub is not the hub, the spoke to spoke connection used to establish the spoke to spoke connection. When it is the hub used to make the spoke to spoke connection that was taken offline spoke to spoke as well as spoke to hub connectivity stops.
I found other than rebooting all of the routers (Spokes and hubs) the command clear crypto sa on the hub and spoke routers allows router connectivity to re-establish.
How should the router IPSEC be configured to prevent this issue. I was hoping that the spoke connection would fail over to the second hub if the first hub fails.
Byron
Hello
duplicate posting  on same forum
https://supportforums.cisco.com/discussion/12591536/dmvpn-dual-hub-routers
Kind Regards
Paul
