Dual Internet Link load-balancing,traffic from Outside Issue
rock981119
Hi All,
  We deploy Cisco Router 2921 at company edge, it has two internet link connect.
Gig0/0 was Fix Public IP:219.134.186.X
Gig0/1 was connect ADSL moden, dialer0 IP was dynamic.
  Like the topology, we configure inside traffic load balance to internet, it is work well.
  But it has some issue from internet traffic to Router own interface address, If packet visit Gig0/0 Fix IP like "ping" or "ssh"
The router probable return packet from dialer0 IP.
  Router seemingly can't identify the fraffic which interface ingress and egress at the same interface. situation like this the router
can't provide some service on it own address. And idear?
  Some config file in attach.
Rock.
32 Replies 32
This evening I can't but tomorrow evening it's possible at 9 PM brussels time, just let me know or tell me which time tomorrow will suit you.
Regards.
Alain
If we change topo like this maybe can resolve my problem:
But i don't have test yet, theoretically i think can be done.
Have you test it yet?
I have the same question on my network
Thanks.
Mohamed,
If I configure both the interface PBR and also the ip local PBR which one would take priority?
Kishore
Hi Kishore,
There is no Priority in this Context.
The Difference is that (Local Policy/PBR) as the name implies is local to the Router, Traffic originated by the router itself is policy based routed, While the (PBR) is a Policy that matches all datagrams hiting an interface (Incoming) Traffic that hits an interface is subject to the PBR.
Mohamed
Hi Mohamed,
Thnks for the reply. I understand that. What I was asking was if I had both of them configured which of them will be used.
So, lets take this thread for eg: traffic is destined to the router so will the router use the policy on the interface or will it use the local policy PBR to reply back
Kishore
Hi Kishore,
it will use the local PBR policy not the other one in this case.
Regards.
Alain
Thanks Alain. Any doco or link to point out what you mentioned. Not that I dont trust you but If I am asked by someone else then I can send them the same link
BTW, please check your PM
Kishore
Hi kishore,
I'll answer you tomorrow.
Regards.
Alain
I did Lab it up...  So to speak, or needed this same function on my router, so I tested both ways:
Code :      C2900-UNIVERSALK9-M), Version 15.1(4)M3
Scenario : I have a default gateway on my 2900 router through an ASA firewall.  I need to be able to SSH to the router, on an external interface, but it uses the ASA for default traffic, so I can either VPN in, and then SSH or implement this work around.
Work Arround Implemented :
ip access-list extended External_Manager_Traffic
   permit tcp host 30.20.10.1 eq 22 any
   permit icmp host 30.20.10.1 any echo-reply
route-map External_Management permit 10
match ip address External_Manager_Traffic
set ip next-hop 30.20.10.2     ! ISP Gateway
ip route 0.0.0.0 0.0.0.0 10.31.120.254
interface GigabitEthernet0/1
description Sip and VPN interface
ip address 30.20.10.1 255.255.255.0
ip local policy route-map External_Management
I tried putting the policy-map on the gig 0/1 interface, but it didn't work.  The router hasn't yet decided the traffic needs to go anywhere when it hits the interface.  It then is sent to CPU and CPU uses routing table to lookup and send to default route.  By Adding the Local Policy route-map we tell the CPU to apply this route map to traffic exiting the CPU.  In this case we bypass the routing table and set the next hop, which triggers routing table lookup for the next hop rather than for the ultimate destination.
Brian S. Turner
CCIE 6145
Could you paste a diagram with the IPs?
I think the outbound SSH traffic (to Internet) response don´t use the 22 port, so this traffic doesn´t match the ACL and won´t be routed through the IP 30.20.10.2 necessarily.
To develop this solution is neccessary identify the outbound traffic to create an appropiate ACL/route, o set a rule to guarantee outbound traffic (ssh response) will be forwarded through que same interface/ISP it was received (ssh request).
I´ve the same problem with a pptp VPN.
My ACL here clearly states to permit return traffic for SSH sessions towards 30.20.10.1.  It doesn't state traffic destined to 30.20.10.1 on port 22, it says RETURN Traffic
Correct version as I have it:
Incorrect verion as you describe wouldn't work :
          permit tcp host 30.20.10.1 any eq 22
The port 22 I'm matching on is for the Source Host TCP port, not the destination host TCP port.
Its working in production using this config.  I really don't have time to do a drawing.  The IP addresses I've changed from production for obvious reasons.
Brian S. Turner
CCIE 6145
I gather based on your answer using the configuration and schema attached, the return traffic (vpn response) should always go back through the router
2. Is that so?
LoadBalancer#
ip access-list extended External_VPN_access
   permit tcp host 192.168.1.150 eq 1723 any
   permit icmp host 192.168.1.150 any echo-reply
route-map External_VPN permit 10
match ip address External_VPN_access
set ip next-hop 192.168.1.101
ip local policy route-map External_VPN
1. in your scheme, the traffic destination is not the router.  so a local policy map, will never match traffic sourced from another device, even if it passes through the routrer.  you would need a normal policy map on the interface. to match that traffic.  remember that ip local policy map only affects traffic from the cpu of the router itself, which is why it works from SSH, to the router, but not pptp through the router.
there are many gotcha's in your design, and it is very different than the topic here.  you should describe what you want to do, and what challenges you are facing with it.  i dont really see that the router has much of a roll there
Brian S. Turner
CCIE 6145
The scheme is the network that I have installed in my workplace, and currently is working perfectly except for the issue of outside access through the VPN, which I think can be solved with a normal policy map as you say. My problem is very similar to the topic.
The role of the Cisco router in the network is to balance the load between the 2routers "fools" of ISPs, and providing failover. It does only static routing with CEF and without Nat, and a single interface connected to the network, which makes both input and output. Behind the balancer is a server that is the gateway and dhcp server (among other things) on my local network. I need the balancer is in-same ethernet segment as the other routers and configure the server to alternate routes on the server directly to the ISP's routers
